Author Topic: Mk2 TT wishbones s3 hubs  (Read 3143 times)
Rsdene
« on: April 22, 2019, 09:03:45 am »
Hi there, could anyone shed any light on my current setup and issues with tt arms?
My setup is as follows, mk2 tt arms, s3 hubs with mk2 tt adjustable ball joints. I have an issue with the track rod hitting the anti roll bar which is a h&r adjustable roll bar. Also the ball joint bolt now hits the inside of the disc. Only does this on the drivers side. The car has ap 6 pot brakes with 362mm discs and h&r clubsport coilovers with adjustable top mounts. Any help would be greatly received cheers
Dene
« Last Edit: April 22, 2019, 09:05:38 am by Rsdene »
Offline Christiank
  • -Receive: 39
Re: Mk2 TT wishbones s3 hubs
« Reply #1 on: April 24, 2019, 06:51:55 pm »
If you're using TT2 parts all has to be TT2 parts
Cupra, S3 and Passat are the same and can be mixed matched - TT2 are different and has be all TT2.. Tie rods, wishbones and hubs
Offline colesey
  • -Receive: 89
« Reply #2 on: April 25, 2019, 05:41:44 am »
Your best bet is probably to replace the TT arms / balljoints with ones from a Passat B6. The adjustable top mounts will give you all the camber you want.
