September 27, 2024, 03:39:32 pm
All Things Mk5
Mk5 General Area
Rear knocking
Topic: Rear knocking (Read 6027 times)
Stefanwalker14
Just Arrived
-Given: 0
-Receive: 0
Rear knocking
April 22, 2019, 11:19:44 am »
Hi all,
Over the past couple of days I have noticed a knocking noise coming from the rear passenger side of the car, only happens when going over speed bumps, small potholes etc.. anyone have an idea what it could be as it’s rather irritating me!
rich83
Just look at my post count
-Given: 165
-Receive: 802
My Ride:
Re: Rear knocking
Reply #1 on:
April 22, 2019, 11:50:24 am »
Could be a few things... you need to look really. Starting place would be arb bushes
https://www.justgiving.com/thenational3peaks
Stefanwalker14
Just Arrived
-Given: 0
-Receive: 0
Re: Rear knocking
Reply #2 on:
April 22, 2019, 12:37:29 pm »
Cheers for the reply I shall have a look but might book in with my local vag specialist as I'm not that mechanically minded
Stefanwalker14
Just Arrived
-Given: 0
-Receive: 0
Re: Rear knocking
Reply #3 on:
April 22, 2019, 02:56:14 pm »
Just had a quick look and the arb bushes look fine to me although perished so might be worth changing? But one thing I did notice was the foam at the top of the shock has started to fall apart so could that be causing the noise or stopping the shock from performing its job?
GTION
Just Arrived
-Given: 1
-Receive: 0
Re: Rear knocking
Reply #4 on:
April 22, 2019, 04:42:55 pm »
Had something similar going over bumps and it turned out to be the rubber stoppers at the end of the parcel shelf string as they dangle around the boot and can hit off the side. It was driving me nuts until I figured it out!
Stefanwalker14
Just Arrived
-Given: 0
-Receive: 0
Re: Rear knocking
Reply #5 on:
April 23, 2019, 05:28:13 pm »
Found the problem, it’s a loose brake disc back plate of all things
rich83
-Given: 165
-Receive: 802
My Ride:
Re: Rear knocking
Reply #6 on:
April 26, 2019, 09:14:36 pm »
Quote from: Stefanwalker14 on April 23, 2019, 05:28:13 pm
Ahh... they are make of tin foil and rust near the screw holes. Glad you found it
pudding
Global Moderator
-Given: 2
-Receive: 685
Re: Rear knocking
Reply #7 on:
April 27, 2019, 01:05:15 am »
That's more of a tinny rattling than a knock though! Knocking normally comes from dead bushes on the swing arms.
Stefanwalker14
Just Arrived
-Given: 0
-Receive: 0
Re: Rear knocking
Reply #8 on:
April 27, 2019, 07:49:16 am »
@Pudding
yes when outside the car it does sounds like a rattle but it was very loose for some reason!
but when driving seemed to make an odd noise, never easy to describe a noise when there’s so many things to make one
All Things Mk5
Mk5 General Area
Rear knocking
