Author Topic: Do I Need To Re-Programme After Fitting Xenons?!?  (Read 5327 times)
Offline Jono76
« on: February 19, 2010, 09:41:24 pm »
I've managed to get my hands on an immaculate set of OEM xenons and will be fitting them once me Kufatec wiring adapter arrives.
My question is that i'm sure i've read somewhere that I will need to re-programme the car once they're fitted, is that true??
Also can the lights be fitted and the car used for a few days before i get it re-progammed if required??
Cheers for the help  :happy2: :happy2:
Offline Jono76
Re: Do I Need To Re-Programme After Fitting Xenons?!?
« Reply #1 on: February 20, 2010, 11:08:54 am »
Anyone  :ashamed: :ashamed:
Offline Beddie
  • -Receive: 76
« Reply #2 on: February 20, 2010, 11:29:46 am »
Think you may just need to do a quick recode using VCDS mate, you need to enable the 'xenon equipped' tick box although iirc there is something to do with having the 'with or without shutter' option depending on whether you have run the wire to the central convenience module to enable the xenon high beam or not
Carbon Grey Edition 35 - Here
Offline Jono76
« Reply #3 on: February 20, 2010, 11:54:14 am »
Now i'm REALLY confused  :ashamed:
Xenon high beam sounds interesting but what exactly is involved, i'm getting the normal Kufatec adapter but i have a horrible suspicion there's more involved?!?!?
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #4 on: February 20, 2010, 11:58:27 am »
as said above you need to run a wire from each xenon to the CM to enable xenon high beam, otherwise you'll ust have the H7 highbeams active  :happy2:
Over the top mod list ;o)
Offline Beddie
  • -Receive: 76
« Reply #5 on: February 20, 2010, 12:03:17 pm »
My understanding (limited lol) of the xenon retro fit is that using the adapters alone will allow the xenon dipped beam to work 100% as normal and will also allow the standard halogen high beam to work too, but...
In order to activate the functionality of the xenon high beam to come on alongside the halogen one you need to run an extra wire to the CCM, depending on whether or not you run this wire determines whether or not to activate the 'with/without shutter' option in VCDS,
The above is due to the MK5 having 'Bi-xenons' as standard which activates a mirrored shutter within the dipped projector beam to give a xenon high beam, the system should work 100% fine without this feature though iirc
Offline QD MBE
  • -Receive: 102
« Reply #6 on: February 20, 2010, 12:08:19 pm »
Doh Too late........................... cheers Beddie.
Jono,
The Xenon light includes a shutter across the xenon bulb.  There are 2 scenarios with this.
1.  If you don't run the wires to the Con Module, then the shutters will not be active, by active i mean they will not have any power running to them.  The shutter moves when main beam is selected and you get a Xenon main beam.
2.  if you don't run the wires, the shutter will be inactive and all you will have is the Xenon dipped beam, and when you switch mains on, the shutter will not move and the halogen will be the only main beam, with a dipped xenon back up.
Coding, if you have not run the wires to the con module, then code them as xenons without shutters fitted, and you will not get any fault codes, if you have run the wires, then code xenons with shutters fitted.
HTH
Offline Jono76
« Reply #7 on: February 20, 2010, 05:48:25 pm »
Jono,
HTH
Cheers for that, at least I understand now :ashamed:
How easy is it to run the wire and whereabouts is the con module???
Offline QD MBE
  • -Receive: 102
« Reply #8 on: February 20, 2010, 05:53:14 pm »
Not too difficult, once you kn ow where the bulkhead grommet is, and the C/Mod is below the fuse box, it has lots of relays on it.
Offline Jono76
« Reply #9 on: February 20, 2010, 06:13:07 pm »
I'll be doing it with one of the technicians from our workshop so I hope he will have some idea!!!
Take it you just need to identify the correct relay?!? Where on the cluster do you need to run the wire from??
Offline QD MBE
  • -Receive: 102
« Reply #10 on: February 20, 2010, 06:20:41 pm »
Might help.......
Taken from the below thread.
http://forums.motivemag.com/zerothread?cmd=print&id=3597373
Offline Jono76
« Reply #11 on: February 20, 2010, 06:31:07 pm »
Cheers Stokeballoon  :congrats: :congrats:
