Author Topic: 1 xenon isn’t self levelling  (Read 3448 times)
Offline Newbieintown
« on: May 02, 2019, 10:43:25 am »
Hi guys had a service on my car and the Passage side xenon isn’t self levelling. All the sensors are working fine and I was wondering if the motor in the headlight could be causing the issue. Anyone else had this issue? Also can I replace it without taking out the head light 👆🏻 Thanks guys
« Last Edit: May 03, 2019, 01:01:47 pm by Andy »
200bhp
Tornado Red
2006
Offline muff1991
  • -Receive: 69
Re: 1 xenon isn’t self levelling
« Reply #1 on: May 03, 2019, 11:47:01 am »
check the actuator arms/arm for the levelling are connected ok on the suspension arm. They're on the rear I think.
« Reply #2 on: May 03, 2019, 01:02:22 pm »
Fixed the link for you
« Reply #3 on: May 03, 2019, 07:38:50 pm »
Thanks bud,
I had the sensors moving both rear and back while using vcds, am going to take out my headlight over the weekend and see if i can fix or order a part that will.
Makes a grinding sound when I turn on my headlights.
200bhp
Tornado Red
2006
Offline muff1991
  • -Receive: 69
« Reply #4 on: May 03, 2019, 11:33:55 pm »
Yeah you’re probs right then... probs the little motor. Hope you find an easy fix this weekend rather than replacing the whole lot.
Offline ady-uk
  • -Given: 19
  • -Receive: 24
« Reply #5 on: May 07, 2019, 08:28:06 am »
I had the problem last year, intermittent fault.
It wouldn't level if starting up normally but once driving along, if I cycled the ignition off and on, it seemed the vibrations of moving along made it level good.  in the end I found it was the plug on the back of the light wasn't fully pushed home.
VW Golf 2.0 Gtd 140 4motion (2005)
Factory fitted: xenons, sunroof, heated leather seats, fold in mirrors with downlights,
Custom: Mk6 steering wheel, updated gateway, RNS510 remote boot pop, LED lighting.
« Reply #6 on: May 07, 2019, 01:42:10 pm »
So they are both working now, but when I turn the ignition on and they level, they both make a grinding sound, I don’t have anyone else’s to compare against. Anyone with factory xenon do yours make a sound when they level when you 1st turn on the ignition? or are they silent? Thanks
200bhp
Tornado Red
2006
Offline ady-uk
  • -Given: 19
  • -Receive: 24
« Reply #7 on: May 07, 2019, 04:49:09 pm »
Mine don't level when I turn the ignition on, only when I start the engine.
Can't tell I've noticed any noise, but doub't I would over the engine noise.
Check the plug is fully pushed home at the back
« Reply #8 on: May 08, 2019, 07:47:02 am »
Mine a silent when they level
