Author Topic: Recon rack fitted, problem!  (Read 5431 times)
Offline Rigsby
  • -Given: 22
Re: Recon rack fitted, problem!
« Reply #15 on: May 13, 2019, 08:18:29 pm »
The sound doesn’t happen when driving in full circle ( driveshaft test)
Literally only when turning the steering wheel, once you stop the sound stops
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #16 on: May 13, 2019, 08:33:24 pm »
have you checked the subframe and rack bolts? Maybe one/some are loose.
Offline Rigsby
  • -Given: 22
« Reply #17 on: May 13, 2019, 08:42:28 pm »
I’ve just put a new rack on mate, noise exactly same before rack change
Offline Rigsby
  • -Given: 22
« Reply #18 on: May 20, 2019, 07:08:32 pm »
Update, now it’s making the noise when not moving.
Lock to lock results in a light knocking which appears to be coming from the drivers
Front area.
