Author Topic: check valve  (Read 2519 times)
Offline titchy
check valve
« on: May 09, 2019, 12:13:32 pm »
My GTI has erratic idle code P0171 there is a check valve 058905291K coming from the vac. pump I assume its a non return valve I can suck and blow through it I assume its knackered Correct!
Offline muff1991
  • -Receive: 69
Re: check valve
« Reply #1 on: May 09, 2019, 03:08:46 pm »
yes mate, that should be a one way valve. you can replace the whole thing with the vac lines for around £30 ish.
Offline titchy
Re: check valve
« Reply #2 on: May 09, 2019, 03:48:12 pm »
Thanks for that. Got a valve £7.00 Bloody useless dealer no help
Offline titchy
Re: check valve
« Reply #3 on: May 11, 2019, 12:48:19 pm »
Had to get complete kit part No.1K0612041GM if it helps anyone
Offline muff1991
  • -Receive: 69
Re: check valve
« Reply #4 on: May 12, 2019, 12:15:45 am »
Was that £7 for the whole thing?
Offline titchy
Re: check valve
« Reply #5 on: May 13, 2019, 11:15:50 am »
No  just a check valve which is an incorrect part [useless dealer] As above valve with 3 pipes £33 from TPS
Offline titchy
Re: check valve
« Reply #6 on: May 15, 2019, 03:40:30 pm »
Got mine from TPS its been modified theres an extra small bore pipe coming off it nowhere to go on my cat so its been blanked Asked dealer and TPS they don't know what its for any ideas?
Re: check valve
« Reply #7 on: May 15, 2019, 04:36:45 pm »
1K0612041GM supercedes the older part and now comes with the surplus vac outlet.  It's a vac feed for engines with mechanically actuated intake flaps.
You used to be able to buy blanking caps from VW, but not sure you still can.   I would just cut it off flush and plastic weld the hole over.
Offline titchy
Re: check valve
« Reply #8 on: May 15, 2019, 06:29:58 pm »
Thanks blanked off with a rubber bung
