Author Topic: Spacer help required  (Read 1494 times)
Offline RobC
  • -Receive: 20
« on: May 09, 2019, 12:19:33 pm »
Has anyone ever had issues fitting 12mm hubcentric spacers on the front of their Mk5? Ive seen a few comments saying if the spigot length is longer than 10mm (mine is 11/12mm) then I cant run 12mm spacers and need to go wider, which I cant understand if the recommended spacer setup is 12mm front and 15mm rear and is run by many people on here?!
Rob
Offline Damian @ DPM
  • DPM Performance
Re: Spacer help required
« Reply #1 on: May 09, 2019, 12:42:08 pm »
A lot will depend on the brand of spacers that you go for, you shouldn't have any issues with H&R 12mm spacers on the front.
Damian @ DPM Performance
Advertising removed... (for the time being)
Offline RobC
  • -Receive: 20
« Reply #2 on: May 14, 2019, 10:29:04 am »
Sorry Damian, only just seen your reply. Thanks for confirming!
Rob
