24° KW is the specified target for the older AXX engine.
BWA, BPY, and others following the AXX are 28° KW.
MB 091 differences reflect something is off in the cam phaser/adjustment system.
Could be anything from; belt side timing, oil pressure and oil flow required for making the adjustments, or something wrong with the related hardware....causing actual to not match the target/specified.
