Author Topic: That time of year air con time  (Read 2078 times)
Offline e4n94
« on: May 14, 2019, 07:26:24 pm »
I purchased my ed30 last august and I never really used the air con until today I went to use it and nothing. The ac button lights up the revs change when turning the ac on and off the fans don't come on.
I checked the codes and had 00898 control circuit ac compressor open circuit
I Then cleared the code check the pump connection all ok and still nothing
Is this a simple Regas or should the fans work
Offline Lucky ducky
  • -Given: 30
Re: That time of year air con time
« Reply #1 on: May 14, 2019, 08:11:38 pm »
Ha! join the club I'm getting nothing not a geek not a fan when I turn it on
did a scan and got  " refrigerant pressure lower limit not reached" code 00229 status static... Dunno what's up with that
Offline e4n94
« Reply #2 on: May 14, 2019, 08:18:23 pm »
Sounds like it's low on gas that does
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #3 on: May 14, 2019, 08:19:43 pm »
Go to ATS, they will recharge your aircon, if the recharge isn't successful you don't get charged.
Offline Lucky ducky
  • -Given: 30
« Reply #4 on: May 14, 2019, 08:31:39 pm »
Thanks guys yeah hope it's just a regas
Offline richtung
  • -Receive: 56
« Reply #5 on: May 14, 2019, 09:28:41 pm »
If you are going to ATS - get the Groupon offer https://www.groupon.co.uk/deals/ats-euromaster-ltd-20
If your budget allows, fork out for the regass and antibacterial treatment (£44.99)
Rich
Offline amanda
« Reply #6 on: May 15, 2019, 01:12:11 pm »
I had mine done at dealers for £49 as I know mine only needs a re gas as radiator and refrigeration unit were replaced about 3 yrs ago ..........
« Reply #7 on: May 15, 2019, 02:12:22 pm »
http://wiki.ross-tech.com/wiki/index.php/00898
Offline amanda
« Reply #8 on: May 15, 2019, 02:18:54 pm »
Ohhhh pudding........straight to the point as always😱🤣  :booty:
Replacement if needed won’t be cheap as I found out!!!!!!
