Author Topic: Front speakers  (Read 921 times)
Offline Andy1982carp
Front speakers
« on: May 17, 2019, 01:29:03 pm »
Hi all fitted on side of my new speakers to my golf last night focal 165as3 now my golf only had two speakers in the front door took my feed from the brown and red and the brown and black from the old speaker plug to the cross over and then rewired the woofer mid and tweeter from the crossover replaced doorcard was all abit right well tried as a comparison to the other side and the new speakers are less than half the volume of the other side help please
Offline Christiank
  • -Receive: 39
Re: Front speakers
« Reply #1 on: May 21, 2019, 09:24:03 pm »
Maybe get someone with VCDS to check if any coding should be done to your radio after installing the aftermarket speakers and putting 2 ekstra speakers to your system.
willni
Re: Front speakers
« Reply #2 on: May 22, 2019, 06:25:15 pm »
Sounds like they're not receiving enough power, would need an amp to sort it out or just turn them up if you're changing them all
