Fuel pressure at idle is 50bar but can’t remember full throttle is, it might be around 125-130bar and obvs in between idle and full is varied depending on input.
If you got VCDS pull up the specified rail pressure vs actual and then difference... you’ll soon know if you’re out mate.
