Author Topic: Airbag fault  (Read 2394 times)
Offline jim85
Airbag fault
« on: May 25, 2019, 07:15:26 pm »
Hi guys, had my headunit out recently and after putting everything back together a headlight warning light appeared, thinking it’s something to do with the switch in glovebox? Anyone have any advice on this
Offline BarryGog
Airbag fault
« Reply #1 on: July 12, 2019, 02:09:40 pm »
I have the same Airbag Fault light but a different code. I have the U0170 code and no idea how to fix it
Offline muff1991
  • -Receive: 69
Re: Airbag fault
« Reply #2 on: July 17, 2019, 11:58:06 am »
another member had a similar issue the other day when replacing his Hazard light switch, turned out he'd not connected the air bag light switch back up fully or had accidently tugged it.
if the lights come on since changing something, then it more than likely will be something you may have accidently done in the process.
