Author Topic: Miss fire  (Read 1870 times)
Offline Stig_gti
Miss fire
« on: June 03, 2019, 09:32:20 pm »
Hi need some help.
Car went for a remap today stage 1 edition 30. Had a call from the tuner car made good power then started losing power.
He checked all the obvious stuff dumpvale, pcv and stuff like this all seems fine.
Done some logging I’ve got a miss fire on Cylinder 3.
Plugs and coil packs look fine recently replaced a month ago all brand new from aks tuning along with dumpvalve and pcv valve. He cleared the codes and he said timing was pulling back to 10 or something on cylinder 3, also looked dry in there.
Offline v4rley
  • -Receive: 104
Re: Miss fire
« Reply #1 on: June 03, 2019, 09:39:02 pm »
Faulty injector would be my guess
Offline Stig_gti
Re: Miss fire
« Reply #2 on: June 03, 2019, 09:41:36 pm »
Would it be best to have them cleaned or replaced. Obviously the injectors ain’t cheap.
Offline Stig_gti
Re: Miss fire
« Reply #3 on: June 03, 2019, 10:06:31 pm »
These where the codes of it helps
Offline Stig_gti
Re: Miss fire
« Reply #4 on: June 04, 2019, 08:24:10 am »
Also mentioned I was getting timing pull on all cylinders, but 3 was the worse -10.
He reckons carbon build up, also never had any missfire before the map.
Offline v4rley
  • -Receive: 104
Re: Miss fire
« Reply #5 on: June 04, 2019, 10:24:13 am »
Send them off to be cleaned. That way you will also get an idea if one of them was faulty
Offline Stig_gti
Re: Miss fire
« Reply #6 on: June 04, 2019, 10:27:40 am »
Ok cheers, now to find somewhere
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: Miss fire
« Reply #7 on: June 04, 2019, 10:44:20 am »
Look at live data and log the misfires at idle - these are normally very consistent when an injector is at fault. Get it done and do not drive the car hard or you'll be looking for a new engine to go with your injectors
Offline Stig_gti
Re: Miss fire
« Reply #8 on: June 04, 2019, 10:46:42 am »
I don’t think it’s miss firing at idle only under hard load
Offline amanda
Re: Miss fire
« Reply #9 on: June 04, 2019, 08:24:13 pm »
I would only remap a car when I was 100% certain everything was working as it should but as as above drive like miss daisy and if I were you I would replace all injectors as in my book they are consumables and need replacement regually
Offline Stig_gti
Re: Miss fire
« Reply #10 on: June 04, 2019, 09:39:14 pm »
Got the car back on standard map driving fine. Scanned the car when I got in no fault codes. Not miss firing or anything, what’s going on
Offline Stig_gti
Re: Miss fire
« Reply #11 on: June 04, 2019, 09:41:40 pm »
This was the timing he was getting when trying to map the car.
Offline Stig_gti
Re: Miss fire
« Reply #12 on: June 07, 2019, 08:50:43 am »
Any ideas  :thinking:
Never had any problems before hand
Offline Stig_gti
Re: Miss fire
« Reply #13 on: June 08, 2019, 10:01:50 am »
Anyone local who can do some logging for me willing to travel I’m based in west London.
Offline Stig_gti
Re: Miss fire
« Reply #14 on: June 22, 2019, 09:46:33 pm »
So update on this,
Changed all injectors as the intake manifold was off anyway and cleaned all carbon build up.
Car was running better but still had the misfire,
We then found out the whole issue was down to the cat. Replaced this today and everything is running great no misfires and no lack of power.
Bit annoying but on the plus carbon has been fully removed and have new injectors.
