Author Topic: S3 Alloy Hubs onto a GTI?  (Read 38027 times)
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: S3 Alloy Hubs onto a GTI?
« Reply #60 on: December 31, 2011, 12:31:47 am »
Thanks Alex
I'll try get pics in the morning  :happy2:
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #61 on: December 31, 2011, 04:55:58 am »
Sounds like the steel insert that is pressed into the alloy hub has stuck onto the passat ball joint.
I had the same issue with a Bentley a few weeks back when I changed the hub/upright for a new one.
Can you get me a pic of the ball joint mount on the S3 hubs and then I can confirm and also a pic of the passat ball joint next to the tt one.
Sounds like that to me also  :happy2:
Over the top mod list ;o)
Offline jimk04
« Reply #62 on: December 31, 2011, 08:48:29 am »
Interesting read as I have one s3 hub and was about to buy a passat one I found!
Hopefully the steel insert has pulled out.
Milltek tbe, Forge intercooler, AMD map, Eibach Sportlines, Porsche 996 over AMG 330mm homegrown BBK
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #63 on: December 31, 2011, 09:20:52 am »
Jim I'm going to put up pics later, but info gathered so far seems to suggest that the passat hubs have a tapered housing in the hub so the TT ball joints don't fit
So hold off on the passat hub for a while
Offline jimk04
« Reply #64 on: December 31, 2011, 12:34:32 pm »
ETKA lists same PN for ally hubbed Passat balljoints and S3 - so they should be the same...
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #65 on: December 31, 2011, 12:57:49 pm »
You're right i've checked through the whole lot and all share the same part numbers ( ball joints, hubs etc )
Photo bucket seems to be playing up so i can't get up the pics yet
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #66 on: January 04, 2012, 08:44:51 am »
OK update on this for all researching this
All seems to be ok, over reaction on my part  :chicken:
Should have researched better  :fighting:
I've since learnt ball joints need to go on top of TT arms to mate with the hubs
Also seems they were S3 hubs all along, so still can't comment on wether passat hubs will work but they share the same part number so can assume there the same and that they will fit
Big fail on my part, sorry for any misinformation :sad1:
Offline mYGeL
    • my Build Thread check it out
« Reply #67 on: February 04, 2012, 12:14:29 pm »
I have a set of Front S3 Alloy Hubs in good condition. for sale if someone is interrested?    :smiley:
Only thing is that they are here in sweden. :P
  • -Given: 243
  • -Receive: 154
« Reply #68 on: February 04, 2012, 12:26:59 pm »
PM me i'm in Denmark and could help you sell them here  :drinking:
TouranTDI
« Reply #69 on: September 17, 2017, 07:22:02 pm »
Through lack of not wanting to revive a dead link
I am posting with the serious need for help
I've had some issues with my Touran 1.9tdi 6spd.
Things I've modded
Polybushed everything bar engine
H&R suspension kit 50mm drop (adapted from 50mm)
TT TFSI Ali hubs (312mm discs) and wishbones
Need TT tie rod ends as mine are on 6 turns
Drop links are fine I believe.
I didn't change the 1.9 shafts
Basically as I have lowered the car the driveshafts have moved from being like
/\ to --- --- so they are sat pressed hard together so the pinion gears are getting hammered and my diff blew,  as there wasn't enough endfloat.
They fitted fine into the 55mm hubs otherwise.
Realistically I need shorter driveshafts or unmodify
Do you know of and driveshafts and/or boxes that will fit (preferably with longer ratios)
Any information would help
  • -Given: 243
  • -Receive: 154
« Reply #70 on: October 18, 2017, 06:04:52 pm »
The TT shafts are longer than your TDI ones so something isn't right if you have issues with TT alloy hubs and your stock shafts are to long
