Author Topic: What Is This & Why Is It Melting?  (Read 2204 times)
Offline JTI
  • -Given: 19
« on: June 25, 2019, 07:36:03 pm »
So car was misfiring 2 weeks back and giving a p0304 code. Changed the spark plugs and it worked fine until this week when it started again but worse, giving a p0302 code. Naturally tried changing the coil packs but made zero difference.
When I was changing them I noticed this plug (see below) has almost completely melted through. Could someone tell me please what this is/does please and if it could cause my symptoms? Thanks
Zoomed out...
Offline Saintsteve
  • -Given: 17
Re: What Is This & Why Is It Melting?
« Reply #1 on: June 25, 2019, 08:04:49 pm »
It’s proberly melting because I’m guessing it started life with a crack in it, and the melt is the Arc’ing going on ?
Tornado Red Edition30 DSG Build Number 114
Atlantic Blue Mk7.5 GTE Advance
Follow Saintsteve330 on Instagram
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #2 on: June 25, 2019, 08:13:37 pm »
Idle control valve or something like that.
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #3 on: June 25, 2019, 09:06:27 pm »
Camshaft adjustment valve N205
Offline JTI
  • -Given: 19
« Reply #4 on: June 25, 2019, 09:22:29 pm »
Thank you! @MIJ_JAGGER yep that's the one. Pelican parts has a guide on how to fix which seems fairly straightforward.
Any ideas on a part number please? Seems that it's either 06F109257C or 06F109257A but they are quite different in price.
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #5 on: June 25, 2019, 09:31:29 pm »
i think the last letter is the revision number so the one ending in C is a newer version than the one ending A, like I say, that's what I think.
