Author Topic: OEM Bluetooth issue  (Read 1259 times)
Offline Rob GTI
OEM Bluetooth issue
« on: February 23, 2010, 05:17:26 pm »
Fitted my BT unit as supplied by VRSStu to work in conjunction with my RNS510 a few weeks ago. While the unit works fine (screen and MFD integration) there is one thing that annoys me when receiving a call the stereo doesn't mute straight away (it takes 3 or 4  rings) and also the "answer" button on the screen and wiper stalk doesn't work for the first 2 or 3 rings either. Is this normal or can it be sorted out with some further coding?
GTI Edition 30 No. 907, 3 door, Black. (Now Sold)
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: OEM Bluetooth issue
« Reply #1 on: February 24, 2010, 09:41:34 am »
It's not something I've been bothered by before, is it handset dependant?  There will always be a couple of rings delay because the phone will need to 'sync' with the BT unit when it recieves a call.
Stu...
Offline Rob GTI
« Reply #2 on: February 24, 2010, 12:42:09 pm »
Its not a major big deal its just that in the Leon I had before (which I assume although not 100% sure) had the same BT unit you were able to answer straight away. Was hoping some more coding may have helped.
Good point about the handset though. Will have to try another make / model to see what happens there.
