Author Topic: Front and rear washer not working and rear wiper stuck on  (Read 5937 times)
Offline Paulo P
« on: July 09, 2019, 11:00:46 am »
Hi,
Firstly I've had a search and I can't see anyone experiencing the same issue.
My wife's 2005 Golf GTI suddenly developed 2 faults at the same time. The front and rear washers don't work (can't hear the motor or a click, wipers work) and the rear wiper won't turn off. Obviously these are somehow related, but how? Which part would this point at?
I have tried the battery reset trick for half an hour and nothing changed.
Thanks,
Paul
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
Re: Front and rear washer not working and rear wiper stuck on
« Reply #1 on: July 09, 2019, 11:22:20 am »
Does the 12V cig lighter still work?
Offline muff1991
  • -Receive: 69
« Reply #2 on: July 09, 2019, 11:39:54 am »
checked the fuse?
Offline Paulo P
« Reply #3 on: July 09, 2019, 11:44:07 am »
I just checked and yes it does.
Offline Paulo P
« Reply #4 on: July 09, 2019, 11:46:51 am »
checked the fuse?
I've pulled fuse (41) for the rear wiper for the moment, I can't find a fuse for the washers in the owners manual.
Offline muff1991
  • -Receive: 69
« Reply #5 on: July 09, 2019, 11:53:00 am »
check fuse 24 mate
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #6 on: July 09, 2019, 12:09:18 pm »
If it’s not the fuse then it’ll most likely be the J59 relay.
It’s located under the drivers side cubby storage thing. It’ll say KL75 above it. Bit of a fiddle to get to mind.
You can try swapping the relay with the opposite side one to see if it’s faulty
Offline Paulo P
check fuse 24 mate
Genius, it wasn't quite fuse 24, it was fuse 42 that was blown. I've replaced the fuse and everything has returned to normal. How odd that a blown fuse can cuase the wiper to stick on.
Thanks for your help, I should have spotted that when I pulled the fuse next to it, I just didn't think a fuse would cause another issue.
Offline muff1991
  • -Receive: 69
« Reply #8 on: July 09, 2019, 12:21:56 pm »
nice mate, good to hear.. i hate electrics lol
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #9 on: July 09, 2019, 12:23:38 pm »
Well this was pointless then lol
Offline Paulo P
« Reply #10 on: July 09, 2019, 12:26:09 pm »
Not at all, it might help someone else later  :grin: Relays was where I was going to go next, I had a look at them last week but I couldn't even pull them out.
Offline mattconroygti
« Reply #11 on: June 25, 2020, 05:03:13 pm »
So I have similar issue with rear wiper and both rear and front washers not working. I have checked all the fuses and replaced the J59 relay. None of that has changed anything. washers or anything not getting any power.
any ideas?
