Author Topic: Bolts  (Read 812 times)
Offline Patters78
Bolts
« on: July 16, 2019, 05:45:28 pm »
Guys help is needed lol
I've lost 3 bolts and just had another strip.
2 of the bolts are from this unsure what it's called
https://ibb.co/qJWTW8G
One goes in here
https://ibb.co/VJ3KxFq
The other is right at the back above turbo
The third bolt is for the under tray there is 3 of them at the back centre with washers on I'm missing one
The stripped one is ok the bolts fine its stripped the thread into the car
https://ibb.co/N1Z6H7Q
I'm thinking I'm gonna need a bigger bolt for this one
Any help appreciated
If anyone can point me in the right direction would be great
« Last Edit: July 16, 2019, 05:47:36 pm by Patters78 »
Offline muff1991
  • -Receive: 69
Re: Bolts
« Reply #1 on: July 17, 2019, 11:23:06 am »
first pic: i think your referring to the inlet pipe. These will probs be T30 and be the exact same as the lower Left boost pipe bolt (as seen in pic 3) Guess the right hands stripped and don't think that's the correct bolt either.. but it might me.
If you remove the lower left bolt from the silver boost pipe, take that to TPS and ask for 3 of those then that should sort you out. But they will also guide you to the bolts you need if you tell them where you're missing them from.. show them the pics too.
as for the under tray bolt, take one of the others out.. take that with you to TPS and ask for one of those too. Should all work out nicely for you mate.
