Author Topic: Brake pedal wobble  (Read 5830 times)
Offline RobC
  • -Receive: 20
Brake pedal wobble
« on: July 24, 2019, 08:21:26 am »
Does anyone else's brake pedal 'wobble' ever so slightly from side to side? Its only a small amount but its very off putting! Ive bought a replacement sleeve, bushes, bolt & nut to replace and hopefully that resolves it but wondered if anyone else had experienced this or fixed it?
Offline f00glee
Re: Brake pedal wobble
« Reply #1 on: July 25, 2019, 11:46:20 am »
Yep. I asked the same question a couple years back and others confirmed that the brake is no where near as stable side-to-side compared to the clutch or accelerator. Mine moves maybe 5mm laterally if i grab it and wobble. I've subsequently gotten over it and don't even notice anymore. Would be interesting to know if these replacement parts firm it up though.
Current:
Mk6 R, Tornado Red, 5-door, '13.
Previous:
Mk5 GTI, Tornado Red, 3-door, '06, R-tech Stage "1+"
Offline RobC
  • -Receive: 20
« Reply #2 on: July 25, 2019, 11:48:12 am »
Good to know Im not the only one then! Ill update the post once with results Ive fitted them  :happy2:
« Reply #3 on: July 26, 2019, 06:05:49 pm »
Does it wobble under braking?  If not, ignore it.  Can't say I've noticed any lateral movement in my pedal.  DSG or manual?  Maybe they're slightly different?
Offline RobC
  • -Receive: 20
« Reply #4 on: July 27, 2019, 09:23:15 am »
DSG. Would love to forget about it but its really off putting in slow moving traffic etc. Will see how I get on with the new bushings.
« Reply #5 on: July 27, 2019, 12:30:03 pm »
Must be that then as all 3 of my pedals have no side to side movement at all. 135K on them.  Good luck with the new parts!
Offline RobC
  • -Receive: 20
« Reply #6 on: July 29, 2019, 02:42:48 pm »
UPDATE - went to remove the bolt at the weekend (its a nightmare as you need both hands, 2 spanners and you've got no room to work it) and it turns out the steering column bracket is in the way! Will have to do some more investigation...
