Author Topic: PRNDS flashing on dash and S lit up on DSG  (Read 3980 times)
Offline dave1814
« on: July 24, 2019, 08:59:43 am »
Hi,
So the other day PRNDS started flashing on dash and the S is lit up on the gear selector, ive read the error codes and got 3 relating to the issue (I think!)...
Address 02: Auto Trans        Labels: 02E-927-770.clb
00194 - Ignition Key Removal Lock
            008 - Implausible Signal - Intermittent
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
2 Faults Found:
            009 - Open or Short to Ground - Intermittent
02413 - Switch for Selector Lever Position P Lock (F319)
However gear shifting seems fine in D, S and using the flappy paddles.
From what i've read im thinking it could be the selector mechanism?
Any ideas?
thanks!
« Last Edit: July 24, 2019, 09:25:09 am by dave1814 »
Offline dave1814
Re: PRNDS flashing on dash and S lit up on DSG
« Reply #1 on: July 27, 2019, 10:15:33 am »
Bump.
Anyone any ideas?
Thanks!
Offline J66hhr
« Reply #2 on: July 28, 2019, 02:54:09 am »
As in the mechatronic but your driving fine in every gear could be a tricky one
Sent from my SM-G935F using Tapatalk
Offline dave1814
« Reply #3 on: August 07, 2019, 04:05:03 pm »
I've just tried running a DSG reset but thats not helped.
One thing I did notice was this....
Is it normal to display 'D' in selected gear when 'S' is actually selected?
thanks!
Dave
Offline andyp
« Reply #4 on: August 18, 2019, 09:04:45 am »
Do these have the same gubbins as on an a4 selector wise?  My mate had the ‘red light’ selector issue and that pointed to the circuit board.  However the magnet had also moved so using a shim on that, it’s actually cured the problem.
