Author Topic: Orange steering light!!  (Read 1128 times)
Offline Rigsby
  • -Given: 22
« on: July 27, 2019, 04:49:48 pm »
My steering light keeps coming on and off and loosing power steering.
Only happens atm when I’m on a spirited drive, quick change in direction etc and light will come in and lose power.
Any ideas fellas? I had a recon rack fitted a few months ago
Offline amanda
Re: Orange steering light!!
« Reply #1 on: July 27, 2019, 05:05:00 pm »
Is it low fluid???
Offline neilw
« Reply #2 on: July 27, 2019, 06:21:55 pm »
Is it low fluid???
Electric steering so there's no fluid. Could be a loose power (electrical) connection.
Edition30 #0002 R-Tech Stage2
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #3 on: July 27, 2019, 06:44:04 pm »
Be careful as if/when it stops working the steering is horrendous with no power, it's not like a non pas rack from the olden days.
Offline Rigsby
  • -Given: 22
« Reply #4 on: July 27, 2019, 07:48:06 pm »
Yeah thought about a loose connection, but I don’t think you can see without dropping subframe
Offline Rigsby
  • -Given: 22
« Reply #5 on: July 27, 2019, 08:49:20 pm »
I’ve just done a scan with Carista.
00778 steering angle sensor (g85)
00446 fuction limitation due to under voltage .
Is it possible the battery could be on way out?
Offline titchy
« Reply #6 on: July 27, 2019, 08:57:23 pm »
check alt output
