Author Topic: New owner, p1297, p0101,p2188  (Read 9352 times)
Offline ryn079
« on: July 28, 2019, 09:57:41 am »
Hi guys, I'm a new owner of a 2007 gti.  I am having p1297, p0101 and p2188.  The main issue is the p1297 which is constant and the other errors come up after driving hard for a long time.  Car has power, but not much in lower rpm.  Diverter valve removed and checked, no broken diaphragm.  What I then noticed is a very strong vacuum when removing oil cap. Any ideas please as I am used to tdis not petrol.  Boost pipes seem ok, no visible oil leak from there.
Offline titchy
Re: New owner, p1297, p0101,p2188
« Reply #1 on: July 28, 2019, 11:24:33 am »
I had a persistant vac leak turned out to brake boost pipe from vac pump to boost valve to crankcase new pipe £33 fixed hope tis helps
Offline amanda
« Reply #2 on: July 28, 2019, 02:07:52 pm »
I had a slight hole in pipe that didn’t show till on full boost.....new black rubber sorted the problem  :star:
Offline Dunkdafunk
« Reply #3 on: July 28, 2019, 05:36:32 pm »
Have you had a look at the PCV valve?
Offline ryn079
« Reply #4 on: July 28, 2019, 06:40:34 pm »
Thanks guys for trying to help. What should I look for in the pcv? How do you detect vacuum leaks and or boost leaks?
Offline titchy
« Reply #5 on: July 28, 2019, 07:34:50 pm »
try unscrewing your oil cap engine running if it gets sucked from your grasp probable pcv
Offline ryn079
« Reply #6 on: July 30, 2019, 02:00:31 pm »
