Author Topic: Chinese carbon canister?  (Read 9103 times)
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« on: July 29, 2019, 01:21:12 pm »
Hi, I'm getting the N80 error in VCDS. I had this last summer and changed the part plus the pipe work to and from the canister.
I am now looking to change the canister, has anyone used the Chinese ones from ebay? I presume the same part from the dealer it will cost a million pounds.
Offline Robsmib
Re: Chinese carbon canister?
« Reply #1 on: July 29, 2019, 01:51:21 pm »
Hi, yes using a moody one off eBay and all been fine since changing it.
Sent from my F5321 using Tapatalk
Offline shoaybmakda
  • -Receive: 54
« Reply #2 on: July 29, 2019, 02:29:45 pm »
I used it in my old MK5 and had no issues at all
Offline suave
  • -Given: 31
« Reply #3 on: July 29, 2019, 10:28:17 pm »
I got one and my car didn’t even tick over correctly with it fitted. Got a refund from eBay as it was rubbish.
Dealer one is £90 odd so not that bad value
Offline Robsmib
« Reply #4 on: July 30, 2019, 09:26:47 am »
Hi, have you changed the purge valve? That's probably causing the fault detected by VCDS, got an oem of eBay UK seller for under £30. Carbon cannister is only a filter.
Offline misteralz
« Reply #5 on: July 31, 2019, 04:09:03 pm »
I kept getting a check engine light and the fault code 'Evaporative purge flow implausible ' or something like that.  It was only every now and then, so it was easy to clear, just annoying. I knew that the cambelt had been changed by a gorilla before I bought it, and the purge valve had been glued back together. I finally got round to replacing it a month back, before a trip to Bavaria.
The check engine light hasn't come back since. The valve was all of 12€ from the dealer. I should have done it five years ago.
Offline muff1991
  • -Receive: 69
« Reply #6 on: August 02, 2019, 02:58:49 pm »
12 euros from the dealer, I paid just shy of £30 and that was at discount from a dealer. fair play.
These issues usually relate to the purge valve and it's those that cause the loud-ish clicky relay - tappet noise too.
of course, if the fault consists then its probably the canister.
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #7 on: August 02, 2019, 03:39:46 pm »
yeah, I changed the valve last summer but over the last 6 months or so I check the EML light come on which I can clear but it eventually comes back after a month or so.  I'm presuming the replacement part hasn't failed after a year but that could be possible.
The canister is coming from China so I'll see what VCDS says after I fit it.
