Author Topic: Torque app air temps  (Read 10953 times)
Offline ellis346
« on: July 29, 2019, 03:26:46 pm »
Hi guys. So I’ve got the torque and been doing some data logging etc. The air temps on there are different than what it says on my dash. Just wondering if the torque app is using a different sensor than the dash? If so what sensor? The temps are always quite similar to the intake temps but have seen the air temp gauge on torque go up to 50c when giving her a good/fast run (weather was hotttt)
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: Torque app air temps
« Reply #1 on: July 30, 2019, 12:20:45 am »
The dash gives the exterior temp, the Torque app gives the intake air temp, so after the IC air temp. Your IC suffers from heat soak.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #2 on: July 30, 2019, 09:11:37 am »
Definitely need a better cooler. On a good blast my temps are within 5-10 degrees of ambient, and that's before the WMI kicks in
Offline ellis346
« Reply #3 on: July 30, 2019, 03:01:07 pm »
Thanks for the reply’s guys. So just to get this straight in my head. the intake air temp (IAT) is the temperature after the IC has cooled the air and the air temp is the temp of the air the intake is taking in? Also dan when you say 5-10 degrees within ambient, can you elaborate? I’m very new to all this. Thanks and sorry for being such a noob
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #4 on: July 31, 2019, 08:16:12 am »
IAT is measured inside the inlet manifold and is the temperature entering the engine. Thew ambient/external air temp is the temperature of the air outside the car. The intercooler should be able to keep the intake temperatures reasonably close to the ambient temperatures.
Offline ellis346
« Reply #5 on: August 01, 2019, 06:54:09 pm »
Thanks dan!  :happy2:
Offline Stig_gti
« Reply #6 on: August 02, 2019, 09:36:00 am »
I have an airtec stage 2 intercooler fitted the weekend,
Outside temps from the Screen was 25. Ob11 in traffic was reading 48
When I started to move and give it a little blip it dropped to 33. Is that good
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #7 on: August 02, 2019, 10:00:13 am »
Sounds about right, in traffic the temps will continue to rise as heatsoak sets in. If I'm in traffic with the A/C on I've seen it creep over 60 degrees on a hot day, soon plummets when the A/C is off or when on the move again.
Offline Stig_gti
« Reply #8 on: August 02, 2019, 11:22:19 am »
Ok thanks will will give the car a good run at a constant speed see where it settles.
Am debating atm stage 2 or stage 2+
« Reply #9 on: August 02, 2019, 04:40:33 pm »
My S3 cooler reads the same.  Ignore IATs at idle because the sensor is downstream of the (closed) throttle plate. It's just measuring trapped heat from the head.
5-10 above ambient at WOT is fine. You will never get ambient temps from any air-air cooler.   The only way to achieve that is with air-water and with ice in the tank, and that's consistent, not just a transient temp drop from meth injection.  Or if you want to get really fancy, run the air-water coolant through the A/C system like the Dodge Demon does.
Probably the best way to improve IATs and throttle response is to bin the massive front mount with silly long boost path, and fit an air-water system from an A45 AMG or one of them off an M5.
« Last Edit: August 02, 2019, 04:42:09 pm by Pudding »
Offline Stig_gti
« Reply #10 on: August 02, 2019, 11:10:45 pm »
Cheers pudding,
It’s no race car but just trying to keep things healthy and running efficient best I can.
