Author Topic: What type radio have I got?  (Read 2532 times)
Offline kodirl
« on: August 06, 2019, 06:55:55 pm »
Hi folks, can anyone tell me why model/type headunit I have in my car, I'm not even sure if it's original VW? I picked a GTI up last week and was wondering if I can retrofit Bluetooth streaming. Thanks
Sent from my Mi A2 using Tapatalk
  • -Receive: 291
Re: What type radio have I got?
« Reply #1 on: August 06, 2019, 07:13:11 pm »
Looks to me like RCD510
Offline The Red Warrior
« Reply #2 on: August 07, 2019, 10:03:48 am »
Yep, as above, RCD510. There are many different versions of that radio. You can get a Bluetooth module for it (there are even some for sale in the classified section of this forum) but in all honesty I don’t think it is worth it. If had a few versions of the RCD510 over the years with a couple different Bluetooth modules along the way. However, I’m now using an RCD330 Plus and it’s better in almost every way. Depending on the version you can get apple CarPlay, Android Auto which gives you streaming, maps, Spotify etc. They all come with Bluetooth built in too so no need to run cables for the microphone and as you already have an RCD510, an RCD330 Plus will be plug and play. No need to worry about CanBus modules or battery drain
Offline kodirl
« Reply #3 on: August 07, 2019, 02:23:06 pm »
Thanks for the info, very informative. One question. Do I need a multi function steering wheel to use the phone function ?
« Reply #4 on: August 08, 2019, 01:58:01 am »
No, no need for multi function wheel as it doesn’t work with the RCD330 Plus anyway unless you also get another part that lots of the sellers of the RCD330 Plus also sell. It’s called a can translator or done such thing.
