Author Topic: inlet manifold clean  (Read 3225 times)
Dave Y
« on: August 07, 2019, 10:44:36 am »
As above this is being done in a couple of weeks.
Anything else i should consider doing while this is being done, any modifications ?
Offline Stig_gti
Re: inlet manifold clean
« Reply #1 on: August 07, 2019, 08:22:46 pm »
Can do runner flap delete, also have all the injectors cleaned.
Dave Y
« Reply #2 on: August 08, 2019, 07:30:49 am »
I spoke to Dan at Turners who said its not worth doing at stage 1 remap,it would cause a lumpy tickover.
I will look at getting the injectors cleaned for now.
Offline Stig_gti
« Reply #3 on: August 08, 2019, 06:53:43 pm »
I didn’t have mine deleted at the time as I was only stage 1 myself, will need new o rings for the injectors as well once you remove them.
Dave Y
« Reply #4 on: August 27, 2019, 02:55:53 am »
having a new thermostat fitted while this job is being done.Is it easier to get at with the manifold off
Offline muff1991
  • -Receive: 69
« Reply #5 on: August 28, 2019, 02:06:34 pm »
Super easy to get at with the manifold off
Offline colesey
  • -Receive: 89
« Reply #6 on: August 28, 2019, 03:35:42 pm »
A good opportunity to fit an RS4 fprv also
Dave Y
« Reply #7 on: August 29, 2019, 03:42:22 pm »
It put an extra £101 on the bill..£60 labour,the rest thermostat + seal.
Offline muff1991
  • -Receive: 69
« Reply #8 on: August 29, 2019, 10:04:48 pm »
What the hell £60 to change that. Id have thought a nice mechanic wouldn’t put labour on changing the thermostat if the manifold is off anyway :-(
Dave Y
« Reply #9 on: August 30, 2019, 12:09:51 am »
i wasnt impressed
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #10 on: August 30, 2019, 09:20:17 am »
Just find a better mechanic for when you next need one
