Author Topic: Larger Wheels and Low Profile Tyres - Less Grip at lower speeds?  (Read 1062 times)
Offline monk180
Hi,
I have larger wheels and lower profile tyres, and I think they have less grip at lower speeds ?
For example turning tight on a mini roundabout in the wet, the car will just push out, and if then input more angle quickly it looses grip faster.
Or even on a larger round about especially in the wet will power under steer sooner.
My only thinking is that a lower profile tyre cannot sort of "load up" like a normal tyre in those conditions, then as the mass of the car rolls, will be a smaller grip patch as force is being pinched to the outer edge, without the tyre deflecting and spreading the load.
Maybe I am wrong or mad, but any thoughts please
« Last Edit: August 10, 2019, 10:39:11 pm by monk180 »
Offline Carpy25
Re: Larger Wheels and Low Profile Tyres - Less Grip at lower speeds?
« Reply #1 on: August 11, 2019, 07:54:27 pm »
Try here lots of information
slip angle on narrow and wide tyres
In Spain atm can’t seem to copy a hyperlink so you my need to google the above
In short it’s not a clear cut as it seams to be the wide narrow question co-efficient of friction and slip angles plus centre of gravity are just some factors that come into play
Sorry for the short reply beer it calling 🍻
Rob
