January 08, 2025, 05:52:15 pm
All Things Mk5
Mk5 General Area
aircon fans
Topic: aircon fans (Read 1161 times)
tyrekika
Just Arrived
-Given: 13
-Receive: 0
aircon fans
August 20, 2019, 03:48:39 pm »
hi all, my air stopped working last year want to try do most repair work myself, need to know if with aircon on should the fans be running as mine dont , any help or advice appreciated.
amanda
Always Involved
-Given: 9
-Receive: 13
Re: aircon fans
Reply #1 on:
August 20, 2019, 04:22:50 pm »
If aircon has failed it will be ......in no order
Needing re gas
Compressor failure
1 or both rads
Or a mix of any above
tyrekika
Just Arrived
-Given: 13
-Receive: 0
Re: aircon fans
Reply #2 on:
August 20, 2019, 08:56:35 pm »
thanks amanda, also if aircon was working fine would the car idle be higher. thanks for help
muff1991
Won't Shut up.
-Given: 8
-Receive: 69
Re: aircon fans
Reply #3 on:
August 21, 2019, 04:25:20 pm »
Quote from: tyrekika on August 20, 2019, 08:56:35 pm
As long as the gas pressure reaches requirements in the system the idle will raise when you turn the aircon on. Doesn’t necessarily mean the aircons working.
pudding
Global Moderator
Just look at my post count
-Given: 2
-Receive: 690
Re: aircon fans
Reply #4 on:
August 26, 2019, 05:53:45 pm »
Yes re: the radiator fans. Put the HVAC on Auto LO and both fans should be blowing at full bifters. If you have VCDS you can output test the fans with the engine off. I do that periodically because you won't know they're working otherwise, unless you get out of the car and pop the bonnet in traffic
If they're not blowing, it could be the A/C is dead, in which case the fan controller won't switch them on.
All Things Mk5
Mk5 General Area
aircon fans
