Author Topic: Abs, traction, steering assistans fault.  (Read 1865 times)
Offline Melkiy
« on: August 22, 2019, 11:42:48 am »
So guys I still have the problem with my power steering and angle sensor g85 won't calibrate at all. I've tried all the tests, I've changed rear bearings with sensors as the was in really bad shape. It didn't resolve the problem.  Test is active for the traction and It won't let me do anything else till its successful and I can't do it cos of this  :thinking:
« Last Edit: August 22, 2019, 12:02:33 pm by Melkiy »
Offline colesey
  • -Receive: 89
Re: Abs, traction, steering assistans fault.
« Reply #1 on: August 22, 2019, 12:14:02 pm »
Have you done any work on suspension recently and need to get the tracking realigned? That can throw the angle sensor out.
Offline Melkiy
« Reply #2 on: August 22, 2019, 12:32:36 pm »
Nop there was no work done on suspension what so ever. Im guessing angle sensor won't calibrate until this wheels speed sensors start to work properly  :sad1:
Offline v4rley
  • -Receive: 104
« Reply #3 on: August 22, 2019, 01:31:23 pm »
Have you check the new wss with vcds to check there isn’t still an issue with them, would be rear but obviously still an option that the new items could be faulty
Offline o-kruse
« Reply #4 on: August 22, 2019, 01:57:33 pm »
I had a ABS sensor with bad wire, damaged wire during other work(shorting interm.) that made those lights go on.
Probably not yours probl, but just in case..
Offline Melkiy
« Reply #5 on: August 24, 2019, 08:52:30 pm »
I've solved that problem with sensors now and only problem now is the test drive, won't let me do the 40168 / 16- security access. Can't get the adaptation done  :thinking:
