Author Topic: Do I need a new LPFP?  (Read 5037 times)
Offline Stamanatic
« on: August 23, 2019, 06:57:49 pm »
Hello,
I've been having this problem for years now and never resolved it but I get a sort of limp mode if I push the car hard in a high gear, feels like a fuel cut but it's not really the car will maintain it's current speed with the accelerator fully pressed, it will not increase in speed but it does not reduce speed.
I've changed my cam follower many times over the years, the fuel thrust sensor I replaced with 06E906051K, fuel filter I'll do this weekend but I had done it a few years ago before I first encountered these faults below.
I saw this https://www.mk5golfgti.co.uk/forum/index.php/topic,37438.30.html thread here that makes it sound like it's the LPFP but if there was really no fuel going to the car when I get these cuts at high speed then surely the car wouldn't be able to maintain the speed? It just feel more like a limp mode of sorts. It can last 1-2 minutes and then suddenly car has full power again.
3 Faults Found:
001089 - EVAP Emission Control Sys
               P0441 - 002 - Incorrect Flow - MIL ON
             Freeze Frame:
                    Fault Status: 11100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 207723 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:20:32
             Freeze Frame:
                    RPM: 747 /min
                    Load: 12.9 %
                    Speed: 0.0 km/h
                    Temperature: 71.0°C
                    Temperature: 19.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.351 V
012555 - Low Pressure Fuel regulation
               P310B - 004 - Fuel Pressure Outside Specification - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 4
                    Reset counter: 255
                    Mileage: 207732 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:47:32
             Freeze Frame:
                    RPM: 2509 /min
                    Load: 56.1 %
                    Speed: 35.0 km/h
                    Temperature: 87.0°C
                    Temperature: 32.0°C
                    Voltage: 13.843 V
000135 - Fuel Rail/System Pressure
               P0087 - 002 - Too Low - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 207810 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:46:30
             Freeze Frame:
                    RPM: 4586 /min
                    Load: 85.5 %
                    Speed: 124.0 km/h
                    Temperature: 90.0°C
                    Temperature: 21.0°C
                    Voltage: 14.224 V
Offline amanda
Re: Do I need a new LPFP?
« Reply #1 on: August 23, 2019, 07:26:35 pm »
Dv or have you checked for slight leaks in hoses that only show up on boost????
Offline Stamanatic
« Reply #2 on: August 23, 2019, 07:35:56 pm »
DV I done last week, I check around the day visually on the hoses, nothing stood out
Offline amanda
« Reply #3 on: August 24, 2019, 09:25:32 am »
I had a hose that visually looked fine but under boost it had a small hole ........took a lot of tracking down but eventually found the little blighter. New hose and no more problems  :signLOL:
My hose was the one linked to dv (n249)
« Last Edit: August 24, 2019, 09:31:06 am by amanda »
Offline Stamanatic
« Reply #4 on: August 24, 2019, 02:16:27 pm »
Did you have the same 2 errors? Because they're low and high fuel pressure related.
             Freeze Frame:
             Freeze Frame:
« Reply #5 on: August 26, 2019, 05:49:33 pm »
Try changing the fuel filter first as they're not part of the service regime.  Some will be well over 10 years old now as a lot of owners don't think to change it themselves. Dealers/indies certainly don't, unless asked to by the customer.
If that doesn't fix it, the in-tank pump or the PWM controller would be next on my list.
Offline Stamanatic
« Reply #6 on: August 30, 2019, 05:39:20 pm »
In fairness the fuel filter was change about 80k ago(7 years), but I changed it anyway the other day, next long run now I'll see if it anything pops up on my next scan.
For the LFPF I see lots of second hand ones on ebay with 1K0919051CL looking like a new enough common revision that you can find there, other the most common revision I see is 1K0919051M but not sure where does M fall, before or after the CL revision.
Then on aliexpress I see some cheap control modules
Offline Stamanatic
« Reply #7 on: September 06, 2019, 08:52:24 pm »
Came back after the filter change this week, LFPF next I guess, just happens really around 6th gear from 100km/h to 160km/h when flooring, that can replicate the issue the most frequent.
Offline andyR43
« Reply #8 on: September 16, 2019, 08:04:31 pm »
Do you run your car on 95 or 98/99 octane. If 95 try 99 and see if the problem persists.  :happy2:
Keeping it original..............or not!!
Offline Stamanatic
« Reply #9 on: September 16, 2019, 10:12:25 pm »
Fitted a new pump yesterday, again same issue replicated when in 6th gear going from 100km/h to 160km/h  this evening, fairly hard to replicate it when in the correct gear, it doesn't look like the HPFP right?
Unfortunately you can't really buy 98/99 where I'm from haha.
Offline mvb12
  • -Receive: 64
« Reply #10 on: September 17, 2019, 11:31:53 am »
what power you running?
Offline andyR43
« Reply #11 on: September 17, 2019, 09:05:15 pm »
Then try some octane booster :wink:
Offline Dunkdafunk
« Reply #12 on: October 05, 2019, 05:07:50 pm »
Limp mode comes in when your fuel pressure is too low. LPFP issues can be solved with a few checks, like reading blocks when the ignition is turned on, but you need a com reader that can read blocks, i paid 30quid for a vag com handheld. Do you still have the last changed cam follower, what sort of wear pattern did you get? What engine code isit?
« Last Edit: October 05, 2019, 05:10:20 pm by Dunkdafunk »
