Author Topic: Coolant Leak  (Read 2404 times)
Offline Rossimac
  • -Given: 78
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,90767.0.html
Coolant Leak
« on: August 26, 2019, 10:40:42 pm »
Picked up a coolant leak, from what I suspect is this pipe with the split hose - you can see the damp patch to the left of the jubilee with the little splits.
Gonna get the pipe changed by my mechanic tomorrow, but I'm just wondering, what's the pink gunge and what can I do to prevent this? Is this the stuff they say is the gunge when you use normal water vs deionised water?
Offline ady-uk
  • -Given: 19
  • -Receive: 24
Re: Coolant Leak
« Reply #1 on: August 27, 2019, 08:15:26 am »
The pink residue is antifreeze, that's why the water is pink....  :thinking:
VW Golf 2.0 Gtd 140 4motion (2005)
Factory fitted: xenons, sunroof, heated leather seats, fold in mirrors with downlights,
Custom: Mk6 steering wheel, updated gateway, RNS510 remote boot pop, LED lighting.
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
Re: Coolant Leak
« Reply #2 on: August 27, 2019, 09:35:19 am »
if you open the expansion tank when the engine is cool/cold you'll see how pink the coolant is.
Offline Rossimac
  • -Given: 78
Re: Coolant Leak
« Reply #3 on: August 27, 2019, 06:18:55 pm »
Yeah I get that, I've been topping it up over the past week with pink coolant. Just, the gunge around the pipe looked a little off to me, is all.
If this seems normal, then I'm happy. Hopefully get the pipe work sorted and it'll be right as rain!
Cheers for the replies.
Offline muff1991
  • -Receive: 69
Re: Coolant Leak
« Reply #4 on: August 28, 2019, 01:49:52 pm »
Perfectly normal mate don’t worry. The pink gunge is literally just dried out coolant. Nothing to worry about. Replace the split hose and you’ll be good as new :-)
Offline Rossimac
  • -Given: 78
Re: Coolant Leak
« Reply #5 on: August 29, 2019, 09:14:42 am »
Cheers, still learning here - had tried to google it but couldn't find anything to tell me otherwise!
Mechanic pulled the pipe up over and past the split, tightened the jubilee and it holds nicely again. All sorted!
He also replaced a CV joint (again) for me while I coded in a couple of new injectors on a Skoda Octavia.  :happy2:
Offline muff1991
  • -Receive: 69
Re: Coolant Leak
« Reply #6 on: August 29, 2019, 12:27:25 pm »
Nice one mate, tbf I didn’t even think of shortening the pipe. If it fits fine and doesn’t stretch much then why not.
