Author Topic: ** VW BKD 2.0TDi (Jetta Sport) - Turbo Pipe - HELP! **  (Read 1422 times)
Offline XxMK5xX
« on: August 28, 2019, 07:16:27 pm »
Hi
Does anyone have a 'part number' for the 'Elbow Turbo Hose' that comes off the turbo?
Mine has a spilt right down the side, would this be causing 'limb mode' & possibly black smoke under hard acceleration?
Thank you in advance  :happy2:
Offline muff1991
  • -Receive: 69
Re: ** VW BKD 2.0TDi (Jetta Sport) - Turbo Pipe - HELP! **
« Reply #1 on: September 02, 2019, 04:46:46 pm »
Hi
If I'm thinking of the same elbow pipe here (the one that comes off the turbo and joins the aluminium pipe to the intercooler then I believe the Elbow hose/pipe part number you're after is:
3C0 145 828 F
I have a BMN engine in the family wagon.. and had to replace this pipe! might be worth double checking this will fit your BKD too but I'm under the impression the BMN and BKD are virtually the same. check it out :)
