Author Topic: what size front brake discs?  (Read 3006 times)
Offline Bad-vw-boy
  • Golfs you gotta luv em!!
« on: September 01, 2019, 10:19:40 am »
I have a 2007 vw golf gti what size are the front discs are they 280mm , 300mm or 312mm..as I cant seem to find a guide advising of this...also looking to put a upgraded drilled disc as a replacement any recommendations on manufacturer, and pads..ebc, Brembo etc?
« Last Edit: September 04, 2019, 01:03:21 pm by Bad-vw-boy »
Mk5 Golf GTI DSG
Offline muff1991
  • -Receive: 69
Re: what size front brake sics?
« Reply #1 on: September 01, 2019, 10:38:16 am »
Pretty sure they’re 312 mate.
Offline Octoparrot
  • -Receive: 102
« Reply #2 on: September 01, 2019, 02:40:41 pm »
Yes should be 312mm front 286mm rear
Offline terrier
  • -Receive: 38
  • My Ride: GTI now gone
« Reply #3 on: September 01, 2019, 08:04:33 pm »
Im using mtec grooved.There good because I have porsche pistons  :happy2: Best discs Ive had were EBC with textar and pagid pads  :happy2: The EBC must be close to £200/axle. There must be deals for pad and disc combo
Offline colesey
  • -Receive: 89
« Reply #4 on: September 01, 2019, 08:54:52 pm »
Am using mtec c hook with endless mx72 pads. Awesome performers and streets ahead of the EBC redstuff I tried before. The latter weren’t bad - had good bite with some heat in them / quiet / low dust - but the MX72 are superb. Also use steel hoses / bronze caliper bushes / ATE 200.
Offline Bad-vw-boy
Re: what size front brake discs?
« Reply #5 on: September 04, 2019, 01:05:12 pm »
I was looking at some Brembo xtra peforated and vented £120 for the pair but not sure what pads...has any one used these discs
Mk5 Golf GTI DSG
Offline KozhichKQ
  • Newbie
« Reply #6 on: October 06, 2019, 12:20:37 pm »
The rear fog light is not intended to be a "4th brake light", it should be wired to the front fogs or a dedicated switch. Write-up is good but it would make more sense to have the rear fog light as a functional modification.
