Author Topic: wheel alignment bad news ,advice please  (Read 9373 times)
Dave Y
« on: September 03, 2019, 10:48:08 am »
I had the alignment done and the fella told me i need two new rear lower arms.
i plan to refurb my suspension over the next few months,could this be the start ? I would like to go a bit better than oem but not too crashy if that makes sense. What do you recommend ?? All advice gratefully received
Offline colesey
  • -Receive: 89
Re: wheel alignment bad news ,advice please
« Reply #1 on: September 03, 2019, 11:18:12 am »
Racingline sports springs / dampers are great oem+ solution for road use and are both better handling and more comfortable than stock.
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #2 on: September 03, 2019, 11:25:07 am »
Did he mean the arms that carry the springs?
If so could be a good time to superpro / Polybush your chassis.
Aks tuning should have them in stock !
Silver is the way !
Offline colesey
  • -Receive: 89
« Reply #3 on: September 03, 2019, 11:51:15 am »
I’ve the road durometer superpro on alloy arms at the front and they are worthwhile. Am rather reluctant to do the rear as big labour costs and potential for noise getting amplified through the boot.
Smaller arbs are also a worthwhile addition, as are the superpro adjustable ball joints however the OP was looking for an OEM+ upgrade rather than full reworking!
Dave Y
« Reply #4 on: September 03, 2019, 12:10:20 pm »
he showed me the arms that go from the middle out to the rear hubs,could be triangular ....I am no mechanic !!!
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #5 on: September 03, 2019, 12:35:03 pm »
yes, the rear arms that carry the springs, think when you go to VW they like you to replace/buy the whole arm with bushes inserted.
Or
aftermarket parts/bushes can be bought separately and pressed into your old arm. Going this way, you probably won't ever have to worry about replacing bushes again. But as stated above it Labour costs can get expensive.
The Superpro bushes cost around £450, front to back.
start pricing the OEM replacements.... Once one bush goes others tend to follow.
Silver is the way !
Dave Y
« Reply #6 on: September 03, 2019, 12:48:30 pm »
the backs are gone so i think i will start there. While these are off is there anything else to replace at the same time ? To save taking this apart in the future
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #7 on: September 03, 2019, 12:49:12 pm »
you might need new bolts...
Silver is the way !
Dave Y
« Reply #8 on: September 03, 2019, 01:42:33 pm »
Do you know the proper name for them and the bolts
Offline muff1991
  • -Receive: 70
« Reply #9 on: September 03, 2019, 01:54:48 pm »
You more than likely will need new bolts.. especially for the inner part as they seize into the collar on the bush! The bolts are called eccentric bolts and the arm is the rear lower control arm. I wouldn’t think you’d need to replace much else if just replacing those arms.. maybe a drop link at the most. But if you want to replace every bush on the rear... it’s like a cluster of bushes and will be expensive.
Dave Y
« Reply #10 on: September 03, 2019, 02:15:48 pm »
who do i go to for these bushes and bolts
Offline colesey
  • -Receive: 89
« Reply #11 on: September 03, 2019, 03:11:20 pm »
Many would say RPS online however their correspondence with an order didn’t impress me however Gavin at VAG Bolts has been excellent.
Offline muff1991
  • -Receive: 70
« Reply #12 on: September 03, 2019, 03:11:26 pm »
You can go to TPS for genuine replacements. But as mentioned you’ll need to press the new bushes in. If it was me (I did) I’d buy the bolts from TPS and then your choice of after market bushes (powerflex etc)
Dave Y
« Reply #13 on: September 03, 2019, 03:23:57 pm »
does anybody sell the arms with aftermarket bushes fitted
Offline scopes
  • -Given: 131
  • -Receive: 116
  • Wolfsburg Edition
    • My GTI
« Reply #14 on: September 03, 2019, 03:29:13 pm »
Have a read here:- https://www.mk5golfgti.co.uk/forum/index.php/topic,121677.0/topicseen.html
This may help point you in the right direction. :happy2:
Silver is the way !
