Author Topic: Carbon cleaning from intake (walnut blasting etc.)  (Read 6505 times)
Offline svvg
« on: September 03, 2019, 03:04:00 pm »
I've seen a couple of interesting, albeit slightly older threads on the benefits of intake cleaning on the FSI engines, including a really detailed guide on this forum. Is this something worth doing on a 113,000 mile AXX GTI engine? If I do decide to do it, is it worth spending the extra on walnut blasting - or is it not worth the cost over DIYing with carb cleaner and plastic/wooden scrapers (which wouldn't be as thorough as walnut blasting)?
There seems to be some doubt over whether performance is affected on turbo engines, whereas the N/A direct injection engines really seem to benefit (like the RS4s etc.).
Any thoughts?
Offline titchy
Re: Carbon cleaning from intake (walnut blasting etc.)
« Reply #1 on: September 05, 2019, 11:57:12 am »
I have read good things about Terraclean
Offline svvg
« Reply #2 on: September 06, 2019, 08:58:39 pm »
Terraclean seems attractive as there’s no need to disassemble much - but folk tend to complain that after an initial quick fix, the car returns to the way it was pre-clean. I think for baked-on, coked-up intakes, manual cleaning/blasting media is probably required. I have a new intake gasket and injector seals - so will probably have a go at DIY cleaning with plastic scrapers and carb cleaner. Won’t be as super-clean as walnut blasting - but not sure the difference will be worth the £300-400 cost...
Offline ljc19630
« Reply #3 on: September 06, 2019, 10:41:44 pm »
Take it to R-Tech and get it done properly
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #4 on: September 06, 2019, 11:23:31 pm »
What measurable benefit is seen after having this done?
Offline svvg
« Reply #5 on: September 07, 2019, 02:02:48 am »
It can help with emissions if this is an issue - and with a lumpy idle. Depending on how gummed up the inlet is (especially if valves aren’t closing properly) it can also restore lost power - but it depends on the engine/mileage etc - hence was asking whether there’s much of a need on the mkv gti with my sort of mileage (113k) as I’m pretty new to these cars.
On the N/A cars with direct port injection they can lose over 20bhp after 60,000-80,000 miles which can be recovered by cleaning the inlet ports (Audi RS4s etc), but I’m not quite sure what folk reckon on turbo cars. I guess it’ll depend on how restricted/gunked up any given car is - but was interested to see if anyone had any strong views.
On terraclean - I think the jury's still out. Tends to get panned as a very short term/possible placebo on BMW forums for N/A cars - but then they don’t suffer with direct port injection issues in the same way (E46 cars in fairness. I’ve not read up much on the effects in the N52 and newer engines in the E90s...).
Manual scraping or walnut blasting seem to be more realistic in terms of cleaning the ports from baked on carbon and sludge on the fsi engines from what I’ve read - but I’d welcome feedback from those who’ve done one or other and can report their experiences??
Offline colesey
  • -Receive: 89
« Reply #6 on: September 07, 2019, 05:30:48 am »
SVVG, you ultimately won’t know what is in there until you get the intake manifold off however a bit of googling should confirm that it is likely that your car will have carbon build up.  I am sure you will be able to get most of that off by manual scraping however it does appear to be a laborious and mucky job. In addition to the walnut blasting, RTech also test and service the injectors and this might be where more of the benefits in responsiveness / cold starting / smooth idling / emissions are coming from.
In terms of quantifiable benefits, I am pretty sure that RTech did a before / after cleaning dyno test showing @10% gains in the midrange but clearly this will vary from car to car.
Offline ljc19630
« Reply #7 on: September 07, 2019, 09:18:16 am »
What he said -  :congrats:
Offline svvg
« Reply #8 on: September 07, 2019, 01:49:31 pm »
Thanks both - the more I’m reading and hearing from forum members, the more this sounds like the way forward. For me, I think I’ll clean the inlets myself, but send the injectors away for ultrasonic cleaning and flow matching.
Offline colesey
  • -Receive: 89
« Reply #9 on: September 07, 2019, 04:24:37 pm »
When you do the maths - is @£150 for injector service plus xxx for gaskets etc - then £350 for Rtech service doesn’t seem much more. They even do a package complete with custom remap for £650.
Offline ljc19630
« Reply #10 on: September 08, 2019, 10:05:37 pm »
What he said
Offline neilw
« Reply #11 on: September 09, 2019, 06:30:44 pm »
Not long until I get the full works! I'll be on here to let everyone know what it's like!
Edition30 #0002 R-Tech Stage2
Offline ljc19630
« Reply #12 on: September 09, 2019, 06:54:50 pm »
Mines been done, minus the injectors, as I provided new ones for the K04 conversion. Just waiting for milly zorst to be delivered and hopefully go up to collect on Saturday
Offline muff1991
  • -Receive: 69
« Reply #13 on: September 10, 2019, 10:01:51 am »
@ljc19630 how's your conversion going? Taking a while isn't it  :thinking:
Offline ljc19630
« Reply #14 on: September 10, 2019, 05:24:24 pm »
Ha Ha, yeah its been a while, but I'm in no rush!!! Had an issue with the exhaust as the backbox was restricting flow and not able to maximise power, hence just bought an R32 style non-res Milly system from eBay that a chap had on his GTi which is arriving Thursday to be fitted. Also, Pip called me today to say that my VIS HPFP had failed and they are getting a new one sent out. He's fitted hundreds and its the first to fail so VIS sending via next day delivery - I may get it back Sat, if not early next week  :jumpmove:
