Author Topic: No power from obd port  (Read 2486 times)
Offline andyp
« on: September 04, 2019, 10:14:56 am »
I’ve two lights on the dash, engine and airbag, borrowed a code reader to see what the actual fault numbers are but I can’t get the code reader to work with the port.  Am I just being thick or does the obd port also have a fuse which may have blown?
Re: No power from obd port
« Reply #1 on: September 04, 2019, 08:50:37 pm »
Have you tried another code reader
Offline andyp
« Reply #2 on: September 04, 2019, 09:40:20 pm »
Managed to get it working,  However the airbag light never appeared as a fault.
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #3 on: September 04, 2019, 10:12:49 pm »
What was it? May help others
Offline FJB
« Reply #4 on: September 05, 2019, 08:14:14 am »
A standard OBD reader will not read and clear airbag fault codes. You need VCDS, OBDeleven, Carly or similar, that can talk to the airbag module.
Free £50 credit when you switch to Octopus Energy using this link: https://share.octopus.energy/pearl-marsh-31
