Author Topic: Golf gt tdi 140 engine issues  (Read 1978 times)
Offline jim85
« on: September 05, 2019, 07:54:08 am »
Hi folks, been having a bit of an issue with my golf, had two mechanics say they have never seen a diesel drive like this before and are struggling to pinpoint an issue, basically what is happening is when the Rev counter hits 2000rpm the car starts juddering feeling like it’s going to stall and the Rev counter starts increasing but no extra power is delivered, car has been mapped so last mechanic said everything mechanically seems sound so suggested an ecu or map issue, got the base map back on by the tuner and he suggested it was a boost issue and it wasn’t meeting the target boost. Just wondered if anyone had a similar problem or could shed some light on it, thinking a second hand ecu coded to my car could be the less expensive option to try next. No lights on the dash showing and the last mechanic said the only error code it was throwing out was once for a glow plug(which he didn’t think was the issue)
« Last Edit: September 05, 2019, 08:48:44 am by jim85 »
Offline ady-uk
  • -Given: 19
  • -Receive: 24
Re: Golf gt tdi 140 engine issues
« Reply #1 on: September 05, 2019, 08:18:00 am »
Hi folks, been having a bit of an issue with my golf, had two mechanics say they have never seen a diesel drive like this before and are struggling to pinpoint an issue, basically what is happening is when the Rev counter hits 2000rpm the car starts juddering feeling like it’s going to stall and the Rev counter starts increasing but no extra power is delivered, car has been mapped so last mechanic said everything mechanically seems sound so suggested an ecu or map issue, got the base map back on by the tuner and he suggested it was a boost issue and it wasn’t meeting the target boost. Just wondered if anyone had a similar problem or could shed some light on it, thinking a second hand ecu coded to my car could be the less expensive option to try next. No lights on the dash showing and the last mechanic said the only error code it was throwing out was once for a coil pack (which he didn’t think was the issue)
Coil pack on a TDI..... I'd change mechanic quickly
Not sure where you are, but I'd recommend Droitwich Diesels, if you're near the midlands.
What they don't know, isn't worth knowing!
VW Golf 2.0 Gtd 140 4motion (2005)
Factory fitted: xenons, sunroof, heated leather seats, fold in mirrors with downlights,
Custom: Mk6 steering wheel, updated gateway, RNS510 remote boot pop, LED lighting.
Offline jim85
« Reply #2 on: September 05, 2019, 08:49:05 am »
Sorry my mistake there was a glow plug lol
Offline titchy
« Reply #3 on: September 05, 2019, 11:55:37 am »
Get it on VCDS before throwing money around cheaper in the long run When was the fuel filter changed?
Offline jim85
« Reply #4 on: September 05, 2019, 12:09:41 pm »
The current garage it’s in has vcds I believe as it’s a be specialist, I spoke to him today and since the map has been put back to base he says it’s started to misfire on idle and he is seeing injector one is causing an issue! I would have thought that would have thrown an error code or atleast engine management light tho??
