Author Topic: 17772/P1364 - Cylinder 4 Ignition Circuit: Open Circuit (HELP PLEASE)  (Read 3668 times)
Offline edition30ldn
hi everyone , been having some rough idle and my boost gauge fluctuates for about 1 mins then the car seems to settle,
just pluged in vag com and geeting this fault 17772/P1364 - Cylinder 4 Ignition Circuit: Open Circuit  anyone had this or can help? changed the coils packs even put totally diffrent coil pick in and same code . this seemed to happen after i had a de cat and had a remap would this be the cause? thanks
Offline Rigsby
  • -Given: 22
Re: 17772/P1364 - Cylinder 4 Ignition Circuit: Open Circuit (HELP PLEASE)
« Reply #1 on: September 06, 2019, 07:09:55 pm »
Check/swap #4 plug, then move onto coil pack loom
« Reply #2 on: September 06, 2019, 07:20:41 pm »
hey thanks for the reply. i changed the coil packs over and the code still showing on 4. how would i go about checking the connection on the harness?
Offline muff1991
  • -Receive: 69
« Reply #3 on: September 09, 2019, 08:49:07 am »
Sounds like you need to have a probe around with a multi metre. Just trace and check wires... must be a damaged or broken one somewhere.
« Reply #4 on: September 15, 2019, 08:27:39 pm »
car still running sh................. if anyone local in london who can help let me know
« Reply #5 on: January 31, 2020, 01:00:41 am »
CAR STILL RUNNING POOP .... ANYONE GOOD WITH ELECTRICS@??
