Author Topic: Golf R calipers  (Read 2932 times)
Offline Cozza
Golf R calipers
« on: September 28, 2019, 08:11:53 am »
Hi guys, new to the forum. I have an edition 30 and heading down the stage 2+ route. In preparation for this I have purchased some mk7 golf R calipers, could anyone suggest a good brake and disc combo to go with this set up? and anything else I would need, maybe spacers? I am keeping the rear standard for now but the pads need doing, again any suggestions what pads I should stick in the rear? Oem or go uprated? Thanks in advance! I apologise if this has been covered before.
Offline ljc19630
Re: Golf R calipers
« Reply #1 on: September 28, 2019, 05:21:54 pm »
I’ve just fitted MK7 R calipers and oem discs/pads as had ko4 conversion. Got the pads and discs as part of the deal and they’d only done 18k. They work fine to be honest and the stopping power is brilliant. A tad more pedal travel, but I soon got used to that. I’ve also got a set of 340mm drilled and grooves discs from M-Tech with mintex pads for when the oem set ware out
Offline Cozza
Re: Golf R calipers
« Reply #2 on: September 28, 2019, 07:33:13 pm »
Thanks for the reply. Are you running R calipers just on the front? And is it pretty much a straight swap? I might get a new set of oem discs and pads to begin with if the stopping power is substantial enough, after all anything is going to be better then the standard brakes I’m currently running
Offline Christiank
  • -Receive: 39
Re: Golf R calipers
« Reply #3 on: September 28, 2019, 08:52:46 pm »
I've got 2 brake kits for up sale incase you're interested?
kit 1:
brand new TTS 4pot front calipers
refurbed R6 calipers
brand new Zimmermann sports drilled discs for front and rear 340/310
brand new Zimmermann sports brake pads for rear calipers
brand new Audi pads for front calipers
brand new protection plates and bolts
Kit 2:
NQSBBK front and rear (Used for around 7-10.000km)
(calipers were all refurbished with new brembo parts and such.)
Porsche 986 4pot calipers front
Caddy rear calipers
Vagbremtechnic J-hooked discs 312/288
Vagbremtechnic brake adapters for Porsche calipers
Ferodo DS 2500 pads front and rear
HEL steel brake lines front and rear
Offline Cozza
Re: Golf R calipers
« Reply #4 on: September 29, 2019, 08:27:30 am »
Do you have any pictures of the brake kits? thanks
Offline Christiank
  • -Receive: 39
Re: Golf R calipers
« Reply #5 on: October 03, 2019, 09:20:28 pm »
Yes,
Send me a mail on T19@altan.dk :smiley:
Offline ljc19630
Re: Golf R calipers
« Reply #6 on: October 03, 2019, 10:28:04 pm »
Yes, just the front. The Mk7R Rear Calipers won't fit as they have the electronic handbrake set up. Fronts are a direct swap. Dont bother with the larger dust shields as the OE MK5 are fine. Cheap conversion and will give you plenty stopping power
Re: Golf R calipers
« Reply #7 on: October 04, 2019, 10:30:54 am »
I use OEM 340mm Clubsport S discs and OEM pads.  At the back I've got recent OEM calipers and pads. That little lot works great with a good pedal.
Initially I had a crap pedal after easi-bleeding it at home, but a dealer bleed and flush through restored the pedal.  There's more than enough stopping power and warp resistance for the road.  For track use it's probably worth using the Clubsport S pads or something from the aftermarket.
Offline Cozza
Re: Golf R calipers
« Reply #8 on: October 04, 2019, 02:15:30 pm »
Thanks for all the input guys. I’m thinking of going for a set of new GTI performance pack calipers (same as golf R I believe). They come with what I presume are oem pads, along with this I’ve found some hel conversion brake lines, also some motul rbf 600 racing brake fluid. Only thing is I can’t seem to find any oem discs? if anyone could link me some that would be much appreciated. Not planning on taking the car on track anytime soon, just looking for a substantial fast road set up for the time being.
« Last Edit: October 04, 2019, 04:32:54 pm by Cozza »
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
Re: Golf R calipers
« Reply #9 on: October 04, 2019, 03:12:36 pm »
1K0615301AD, part number for OEM discs
TPS or dealers
