November 16, 2024, 03:33:26 pm
All Things Mk5
Mk5 General Area
Fault code
Topic: Fault code (Read 996 times)
Tally
Can't Read PM's Yet!
-Given: 0
-Receive: 0
Fault code
September 28, 2019, 02:55:45 pm »
Anyone ever had issue with.
Fault code P0275 intake temperature sensor G4 signal too high. P0113 lower limit reached. Intermittent
muff1991
Won't Shut up.
-Given: 8
-Receive: 69
Re: Fault code
Reply #1 on:
September 30, 2019, 03:04:21 pm »
doesn't ring any bells to me, but first i'd check the wiring.. one will be the earth and the other should give you around 5v. if all ok then replace the sensor.
All Things Mk5
Mk5 General Area
Fault code
