Author Topic: Swapping front brake pads?  (Read 1751 times)
Offline Jaywoo-GTI
  • -Given: 38
« on: February 26, 2010, 03:57:03 pm »
Do i require any special tool or is it pretty straight forward?
Offline DaveyCupra
Re: Swapping front brake pads?
« Reply #1 on: February 26, 2010, 04:01:33 pm »
It is pretty straight forward:
- Loosen the wheel
- Jack up the car (make sure handbrake on and wheels chocked)
- Secure with axle stands
- Take wheel off and use a screwdriver to prise out the metal retaining clip that holds the pads in tight.
- Use the correct size socket and rachet to remove the caliper
- Remove the old pads and then use a G-Clamp to push the piston back in to allow you to fit the new pads
Then rebuild in reverse order
Offline Jaywoo-GTI
  • -Given: 38
« Reply #2 on: February 26, 2010, 04:11:16 pm »
Nice one, So the same as every other car then, was worried that it was more complicated than that as VW wanted 100 quid to fit them.
Offline DaveyCupra
« Reply #3 on: February 26, 2010, 04:42:42 pm »
No worries mate, just the same as any other car, the dealer just wanted to get the most he could out of you lol.
Offline FamilyDub
  • ...who needs a diesel?
« Reply #4 on: February 26, 2010, 05:13:00 pm »
:confused: Bl00dy heck... that's a lot.
Nice tips, I'd even give it a go with clear instructions like that!
MKV GTI | Reflex Silver | 5-dr, Family-Spec | 17" w/anthracite Finish | Manual | Highline | Cruise | Revision 'D' DV | Dirty Pipes |
Offline DaveyCupra
« Reply #5 on: February 26, 2010, 05:27:52 pm »
Here you go mate, the link below shows you all you need to know. It is for a Mk2 SEAT Leon but the bolts and the process is identical for your car.
http://www.seatcupra.net/forums/showthread.php?t=192247
Offline nc35
  • -Given: 40
« Reply #6 on: February 26, 2010, 11:03:12 pm »
think it is a 7mm alan key, the one that never ever seems to come in a set. Got one to fit my socket set for a couple of quid from europarts.
Make sure you have one before you start.
If you are local can lend u mine
Had another look this morning - deffo a 7mm alan. (Not 17 if you read this earlier) sorry
« Last Edit: February 27, 2010, 10:34:07 am by nc35 »
No Golf anymore.
Enjoyed the last five years of ownership of Mk5 & 6 GTIs.
Plus an excellent forum for knowledge and new ways to deplete the bank account.
Thank You Everyone.
