Author Topic: Ed30 ecu  (Read 965 times)
Offline Dunkdafunk
Ed30 ecu
« on: September 29, 2019, 09:07:41 pm »
Will a byd ed30 ecu fit onto a bwa engine? If so, would the bhp increase?
Dunk
Offline muff1991
  • -Receive: 69
Re: Ed30 ecu
« Reply #1 on: September 30, 2019, 02:24:31 pm »
i will fit yes, everything will/can fit. but it probably wont run, or wont run well as the values will all be different.
if you're looking at replacing your ECU, you need to replace it with the exact same unit ideally (including the last letter of the part number will have to be the same)
