Author Topic: Cloudy headlights  (Read 2892 times)
Offline FastSchnitzel41
Cloudy headlights
« on: October 13, 2019, 01:31:25 am »
Hi chaps, my headlight lenses are a little bit cloudy; I gave them a rub down today and they're a bit better.  I heard about someone using toothpaste on them to clean them up in the past - does anyone on here do this?
Offline colesey
  • -Receive: 89
Re: Cloudy headlights
« Reply #1 on: October 13, 2019, 08:42:09 am »
Toothpaste is just another abrasive polish. It didn’t work on mine, nor did paint cutting compounds so I called in the pros to do it with multiple grades of sandpaper.
Offline muff1991
  • -Receive: 69
« Reply #2 on: October 13, 2019, 09:54:10 am »
2 options for amazing finishes...
Meguiars: 2 step headlight restoration kit
Maguiars: headlight restoration kit plus
I have only used the plus one, but the 2 step came out after, The plus I have used many times on mine and other headlights, but a mate of mine has used the 2 step (which comes with the clear lacquer spray) and says it’s also brilliant! I promise you it’s the best way and for £22 it brings the headlights like new and is dead easy to do.
Offline Octoparrot
  • -Receive: 102
« Reply #3 on: October 13, 2019, 01:06:53 pm »
I've heard good reports on 3M headlight restoration kit. Forget toothpaste.
Offline DaveyBoyWonder
« Reply #4 on: October 14, 2019, 08:08:09 am »
Might give that a go. Got the one without the lacquer and the lights just cloud again after a couple of months.
Offline titchy
« Reply #5 on: October 14, 2019, 09:18:14 am »
I have bought a few kits but the best thing I have used is lemon juice and baking soda make a paste rub on rub hard wash off with water brilliant on my GYI and nephews Cotse
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #6 on: October 14, 2019, 11:56:29 am »
I've used a few different grades of wet and dry sandpaper and them some megs cutting compound.
Offline ljc19630
« Reply #7 on: October 14, 2019, 05:09:57 pm »
2000 grit wet sand with machine polisher. Then use cutting compound with a good microfibre cutting pad. Then a finishing polish with a microfibre polishing pad. Finally, coat with Chemical Guys hydro slick ceramic paste. Trust me they will look like new
Offline BigstickytoffeeGTI30
« Reply #8 on: October 14, 2019, 06:35:39 pm »
Mine only clouded over again after the protective lacquer (or what was left if it) was taken off in the restoration. 2nd time I tried lamine-x film after restoration which I was never 100% happy with. Ended up getting 2 new oem hella lights off eurocarparts for £300 when I gave the car a make over earlier this year.
Offline AliGTI
  • -Given: 28
« Reply #9 on: December 24, 2019, 12:53:10 am »
I've tryed a few kits and suggestions over the years on my GTI. I gave up and stripped out the lights, heated them in the oven and melted the adhisive. Removed the old lense and replaced with some I found on ebay for about £30. After 2 years they are still perfect :-)
Offline shoaybmakda
  • -Receive: 54
« Reply #10 on: December 24, 2019, 02:23:46 pm »
This will do the job for you. Obviously depending how bad they are you may need to get lower grade paper.
