Author Topic: brake booster valve  (Read 5754 times)
Offline titchy
brake booster valve
« on: October 23, 2019, 03:46:53 pm »
Car running rough found brake booster valve pipe to a n plastic pipe in crankcase broken any one know if this is a replaceable part?
Re: brake booster valve
« Reply #1 on: October 23, 2019, 04:35:05 pm »
If you mean the pipe from the intake manifold to vacuum pump, it's one piece.  The check valve part isn't available separately.
Offline titchy
« Reply #2 on: October 23, 2019, 05:07:07 pm »
The pipe and valve are recent where the pipe goes into the engine theres a plastic pipe fixed what I assume is the crankcase  that has snapped Thanks for your reply I am waiting for dealer to ring back
Offline titchy
« Reply #3 on: October 23, 2019, 06:19:09 pm »
o.k the plastic part is available common fault the plastic degrades over time causes idle fluctuation and breaks when you remove the pipe which is what has happened I will post again when I get the new part may help someone else
Offline titchy
« Reply #4 on: October 25, 2019, 01:43:48 pm »
Useless dealer got wrong part, suggested I book into workshop at squillions pounds an hour. I asked them to contact VW tech for advice  Car off road for a bit of broken plastic
« Reply #5 on: October 25, 2019, 01:54:36 pm »
Are you talking about this part?  Not my pic, found it on the net.
Offline titchy
« Reply #6 on: October 25, 2019, 03:23:19 pm »
No not far off though the pipe that goes down from there  goes into another pipe I will try posting a  pic. Thanks for your help  the pipe goes from the one way valve down onto plastic pipe cant post photo don't know why
« Reply #7 on: October 25, 2019, 03:44:04 pm »
OK no worries.  Well that whole pipe assembly is sold as one piece like this, if it helps.
Offline titchy
« Reply #8 on: October 25, 2019, 05:12:56 pm »
Thanks again VW tech have said the pipe goes from a junction fixes to the bottom on the assembly  you pictured  then goes around the bulkhead to the servo so I am getting that Tuesday
Offline titchy
« Reply #9 on: October 29, 2019, 03:53:02 pm »
VW sent another wrong part cant find what I need on any diagrams suggested I book into workshop for diagnosis at £90 I declined   booked in at a local guy tomorrow I took photos drew a diagram still dealer couldn't help said he had been in parts for 30yrs never failed before he has now off the bloody road for a piece of plastic
Offline FJB
« Reply #10 on: October 29, 2019, 04:04:17 pm »
The bottom pipe in the above picture goes into the the coolant flange part number 06F121132H which acts as a coupler and joins it to the brake servo pipe.
Free £50 credit when you switch to Octopus Energy using this link: https://share.octopus.energy/pearl-marsh-31
Offline titchy
« Reply #11 on: October 29, 2019, 05:38:54 pm »
Thanks bloody dealer coulndt work it out
Offline titchy
« Reply #12 on: October 29, 2019, 06:03:56 pm »
Just checked a pic bang on £18 in dealer. Cant thank you enough for that Kevin
Offline titchy
« Reply #13 on: October 30, 2019, 09:49:41 am »
Anyone got how long it should take to fit above flange? Its booked tomorrow the guy hasn't done one before
Offline titchy
« Reply #14 on: October 31, 2019, 07:39:15 pm »
Got new part today took to garage they rang to say it wouldn't fit without a modified clip for one of the pipes off the road till tomorrow. No mention of it when they handed it over. Bloody useless
