Author Topic: brake booster valve  (Read 5409 times)
Re: brake booster valve
« Reply #15 on: October 31, 2019, 07:56:41 pm »
did you get the plastic plug that fits over that open small bit of plastic pipework? I suspect that's what your garage says is missing.
it's part number is 056 129 777
Offline titchy
« Reply #16 on: October 31, 2019, 08:50:11 pm »
They just told me its a modified clip fitting so not sure find out tommorow
« Reply #17 on: November 01, 2019, 01:41:15 pm »
Just checked a pic bang on £18 in dealer. Cant thank you enough for that Kevin
No worries mate.  Good luck with your MK7 if you buy it  :happy2:
Offline titchy
« Reply #18 on: November 01, 2019, 02:25:28 pm »
Car sorted £80 glad to get back behind the wheel Thanks for heads up
Offline roryscott30
« Reply #19 on: May 15, 2020, 09:46:34 am »
Hi there,
I was changing my gearbox clutch yesterday and I snapped that damn pipe. I think it must come from the servo then joins into a piece which also has water pipes. Is the vacuum part just a way of connecting both pipes ie can I just re-route with another pipe and by pass this? If not does anyone have the part number for the tree?
Offline FJB
« Reply #20 on: May 15, 2020, 02:03:52 pm »
If it is the the coolant flange just above the gearbox you are talking about, then the bottom pipes just connect 2 pipes for the heater matrix, the 2 pipes above that connect the vacuum pipes together. If you have just snapped off one of the vacuum pipes then you can just connect the 2 together and bypass the flange and all will be good.
Free £50 credit when you switch to Octopus Energy using this link: https://share.octopus.energy/pearl-marsh-31
Offline roryscott30
« Reply #21 on: May 15, 2020, 02:42:15 pm »
That’s great thank you. One less item off the list!
