Author Topic: Rear caliper - Snapped hard pipe  (Read 2754 times)
Offline reidy-
« on: October 26, 2019, 05:46:37 pm »
Hi Guys,
A quick one as need to sort asap,
changing my rear caliper, undoing the near side (rear left) hard pipe to the flexi and it has snapped in two,
I need a replacement asap, any thoughts on who will stock one on Sunday? I am based J28 of the M1, euro car parts looks like it only has the flexibles
Will consider a 2nd hand one if someone has one readily to hand
Offline titchy
Re: Rear caliper - Snapped hard pipe
« Reply #1 on: October 26, 2019, 06:19:04 pm »
Go to any motor factor they make b/pipes couple of quid
« Reply #2 on: October 26, 2019, 06:55:04 pm »
Yeah that's quite common.  Had to replace that on mine as well.  I bought a new pipe from VW, but as above, if they won't do it for you, you can buy a brake flaring tool, a length of pipe and some fittings from the motor factors and sort it tomorrow.
Offline reidy-
« Reply #3 on: October 26, 2019, 07:25:35 pm »
Ok Thanks guys, good suggestions I'll give that a try tomorrow morning.
Are the threads universal fit do you know? or is each end thread specific?
Offline titchy
« Reply #4 on: October 27, 2019, 08:52:06 am »
They are metric short if you take the pipe to a factors they will sort it
Offline reidy-
« Reply #5 on: October 28, 2019, 08:39:26 pm »
Right after an amount of faff, we tried to make a pipe at a local shop on sunday and they ended up just destroying what was left at the fittings so called it a day and ordered a replacement next day delivered.
I fitted the part today, however the flexible is sitting at quite a significant angle, and is so much so I cant get the locking clip in, essential I think the hard pipe is a smidge misshapen forcing the flexi slightly out of alignment
what do you think? I cant see a huge issue not having the clip there
https://imgur.com/IwuNxfC
« Reply #6 on: October 29, 2019, 08:15:08 am »
Loosen the metal pipe but not out of the threads and put the clip on
