Author Topic: Hesitancy while driving  (Read 2097 times)
Offline kodirl
« on: October 26, 2019, 08:41:39 pm »
Hey folks. I have had a lot of work
done recently on my GTI but I'm noticing that when driving on the motorway it seems to jump maybe 100-200revs for a second before going back down. This happens across the rev range and even when I have the cruise control on . It is very annoying to say the least as the car speeds up ever so slightly and then slows down and repeats the process. Has any one any idea what could be causing this?
Sent from my Mi A2 using Tapatalk
Offline titchy
Re: Hesitancy while driving
« Reply #1 on: October 27, 2019, 08:50:34 am »
Does this happen at idle?
Offline kodirl
« Reply #2 on: October 27, 2019, 12:09:04 pm »
No. Only when it's on the move.
Offline titchy
« Reply #3 on: October 27, 2019, 05:20:56 pm »
possible leaky injector over fuelling
Offline kodirl
« Reply #4 on: October 27, 2019, 05:22:38 pm »
Is there any way of doing DIY check to confirm this?
Offline titchy
« Reply #5 on: October 28, 2019, 10:56:40 am »
best put on vcds
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #6 on: October 28, 2019, 11:28:09 am »
What intake and what are your fuel trims? Sounds like an air leak to me, PCV could possibly be faulty
Data logging with VCDS (or similar) is the next step
« Last Edit: October 28, 2019, 11:31:17 am by Dan_FR »
Offline kodirl
« Reply #7 on: October 28, 2019, 11:43:22 am »
Standard intake. Fuel trims?
Offline titchy
« Reply #8 on: October 28, 2019, 12:02:34 pm »
you will need a scanner with live data function to check fuel trims hence vcds
Offline kodirl
« Reply #9 on: October 28, 2019, 12:04:26 pm »
Ok cheers
Offline kodirl
« Reply #10 on: October 28, 2019, 12:05:28 pm »
Is there a recommended vcds that I could buy . Obviously don't want one that's goin to cost a fortune but one for a DIY'er
Offline titchy
« Reply #11 on: October 28, 2019, 04:13:10 pm »
Gendan do a diy one around £220  a decent garage should charge around £45 theres a few here who have them if you can find someone near
Offline kodirl
« Reply #12 on: October 28, 2019, 04:28:48 pm »
Cheers mate for the information
