Author Topic: Power folding mirrors  (Read 2131 times)
Offline leec1969
« on: November 05, 2019, 04:10:11 pm »
Hi guy will a 2005 door module work ok in my 2007 gti
Sent from my SM-G965F using Tapatalk
Offline Christiank
  • -Receive: 39
Re: Power folding mirrors
« Reply #1 on: November 15, 2019, 08:36:41 pm »
Not without swapping wires from your Gen3 module to Gen2
So easy answer is no it wont work unless you're up to the challenge of wire swapping in the door harness
Offline leec1969
« Reply #2 on: November 15, 2019, 08:39:30 pm »
Thanks for that any idea  what door module I will need cheers
Offline Christiank
  • -Receive: 39
« Reply #3 on: November 15, 2019, 09:16:54 pm »
motor index should be N or Q on Gen3 MAX modules.
I just used Mk6 modules in mine.. 5K - 792A/793A (electronic module partnumber and not regulator motor partnumber.)
Offline leec1969
« Reply #4 on: November 15, 2019, 10:13:56 pm »
Cheers can I only use 3 door module not 5 door will these fold on key
Offline LC5F
  • -Receive: 80
« Reply #5 on: November 17, 2019, 12:54:38 pm »
I understood folding mirrors was manually activated - it is on my 2006.
Automatic fold would be a nice upgrade
Offline leec1969
« Reply #6 on: November 17, 2019, 01:07:18 pm »
Yes they are but I am sure you can use a seat door module to do it but don't know about the mk6 door module
Offline Christiank
  • -Receive: 39
« Reply #7 on: November 18, 2019, 01:24:08 pm »
+Gen3 modules can be changed in EERPOM to allow mirror fold with comfort lock on the remote button.
None of the modules that'll fit the mk5 can fold by only pressing lock buttons once - you need to hold the button and use comfort closing.
However if you swap you old CECM+CCM modules and build it all over to a BCM like I did - then It's possible to change the comfort press time on the remote in the BCM EEPROM :)
