Author Topic: Checking CAN Gateway  (Read 3280 times)
Offline kpowell911
« on: November 10, 2019, 12:05:57 pm »
Hello, Im upgrading my head unit to the later RCD330. I'm aware I may need to change the CAN Gateway in order to stop the battery drain.
HOWEVER, I've also read that at some point they crossed over to the new CAN Gateway and as mine is a later MK5 I may already have this. This would be ideal as although the cost of upgrading isn't the issue, I don't have access to VCDS so would need to find someone....
Is there anyway I can check what CAN Ive got before I start? Failing that, once the Head Unit is installed, is there anyway of knowing wether its draining the battery other than waiting for the battery to die? Will it turn on with no ignition if the CAN Gateway is too old for example to confirm that the upgrade is needed?
Offline shoaybmakda
  • -Receive: 54
Re: Checking CAN Gateway
« Reply #1 on: November 10, 2019, 05:22:10 pm »
@kpowell911 VCDS would be the easiest way but the other option is taking the gateway out.
Where are you based? Might be able to find someone local to give it a quick scan?
Offline loop
  • -Given: 26
« Reply #2 on: November 11, 2019, 01:56:05 am »
What year is your car?
‘05 GT, Retrofits: RNS 510 DAB+, R32 Highline Cluster, R32 MFSW, Mk6 Reversing Camera, 7P6 Bluetooth, TPMS, Cruise Control, VW MDI, Chrome switches, Blaupunkt THA 475 amp.
Offline kpowell911
« Reply #3 on: November 11, 2019, 05:40:47 pm »
its a 2007 which I believe is on the change
Offline loop
  • -Given: 26
« Reply #4 on: November 12, 2019, 08:46:08 pm »
I think you will be ok with that, more so if it’s late 07.
Offline kpowell911
« Reply #5 on: November 13, 2019, 09:33:39 pm »
July 07, so earlyish.
If i put the unit it, how will I know its draining the battery? Will the unit turn on with no ignition? How long does it take to kill the battery? I just want to know so I can test it as I dont always use my car
Offline shail
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,99663.msg979899.html#msg979899
« Reply #6 on: November 13, 2019, 10:02:51 pm »
Mines a July 2007.  Scanning it with a generic scanner my can gateway part number is 1K0907530K which from reading up will need changing.
Offline loop
  • -Given: 26
« Reply #7 on: November 13, 2019, 11:10:56 pm »
If you leave it in the car overnight there’s a chance that the battery could be drained by the following morning. Depends on health of battery to start with.
July 2007 I think is borderline whether you will be affected, afraid I don’t know the exact cut off date, if you have a search of past threads on here you may find the info.
Offline MIJ_JAGGER
  • -Given: 103
  • -Receive: 78
« Reply #8 on: November 14, 2019, 09:16:07 am »
Have a K on my 2007. No battery drain with an RCD510
Offline kpowell911
« Reply #9 on: November 14, 2019, 06:56:29 pm »
I've put the head unit, it works flawlessly which is great, but Ive not bolted anything down and Im going to leave it till Saturday and see.
However, Im able to turn it on without the key in the ignition so Im guessing I need to change the Gateway..... I'll see.
Im in Birmingham, what's the best way of getting this done and what sort of money should it cost?
Offline titchy
« Reply #10 on: November 14, 2019, 07:00:24 pm »
that's normal it should go off after the doors close
Offline kpowell911
« Reply #11 on: November 14, 2019, 07:42:13 pm »
Doors close or doors close and are locked?
Offline kpowell911
« Reply #12 on: November 15, 2019, 05:58:59 pm »
Looks like I need it. Can anyone recommend someone to supply and fit one in the Birmingham area? If so how much should I expect to pay?
Offline kpowell911
« Reply #13 on: November 16, 2019, 06:54:12 pm »
Thats confirmed its killing my battery. Booked in with Alex @ VW Retrofit to sort out the Gateway on Monday
