Author Topic: Anyone know what could be causing this fault code??  (Read 2006 times)
Offline kodirl
« on: November 17, 2019, 06:16:22 pm »
Hey folks car seems down on power in the lower gears when driving. Idle is consistent around 700rpm but when driving at a steady 70mph revs seem to go up and down by 100rpm every couple of seconds. Below is scan diagnostic from obdeleven. Any ideas?
Sent from my Mi A2 using Tapatalk
Offline djdownes69
  • Newbie
Re: Anyone know what could be causing this fault code??
« Reply #1 on: November 20, 2019, 09:47:20 pm »
Hi kodirl it could well be the diverter valve located near the turbo they are know to split mine did and now power is back hope this helps
« Reply #2 on: November 21, 2019, 12:49:39 pm »
The fault code and the first live data screen shot indicate a bad MAP sensor.  1.6 bar of boost at idle?   :grin:
Offline kodirl
« Reply #3 on: November 21, 2019, 01:22:34 pm »
Thanks. What should normal level be at?
« Reply #4 on: November 22, 2019, 11:55:53 am »
1000mb as the MAP sensor is in the boost pipe, so doesn't read vacuum.
Offline kodirl
« Reply #5 on: November 22, 2019, 11:57:34 am »
Cheers mate. Have one ordered now so hopefully it does the trick!
« Reply #6 on: November 22, 2019, 12:01:54 pm »
Fingers crossed  :happy2:
Offline kodirl
« Reply #7 on: November 23, 2019, 06:50:57 pm »
Thanks buddy, after going to install my new map sensor today it turned out the old one wasn't even connected . The mechanic who did my timing belt and thermostat obviously didn't reconnect it. Great to have my car back again as it was seriously down on power. Now to try and bring back the map sensor and get my money back .....
